rebuilt 390 Question
Old Nov 11, 2013 | 04:07 AM
  #76
stromburg's Avatar
stromburg
Originally Posted by montana_highboy
Grrr put some real gauges on there, mechanical or electrical, your option (though I highly recommend mechanical)
What bearing clearances are you running?
.0015 mains
.0018 rods
Old Nov 11, 2013 | 04:11 AM
  #77
montana_highboy's Avatar
montana_highboy
Originally Posted by stromburg
.0015 mains
.0018 rods
What weight oil? (after break in) 10w30 or 10w40? synthetic or carbon based?
Old Nov 11, 2013 | 11:19 AM
  #78
stromburg's Avatar
stromburg
10w-40w valvoline racing with zinc (not synthetic), I never really put much thought into oil except for the zink additive, I would be very open to a good recommendation though
Old Nov 29, 2013 | 02:55 AM
  #79
stromburg's Avatar
stromburg
here's my chief mechanic getting the new engine ready to go in/
Old Nov 30, 2013 | 06:52 PM
  #80
dakotarider's Avatar
dakotarider
Stromburg, NICE cherry picker, Cool driver and not a bad looking motor! Hopefully you got her in before our weather hit. Give us the install pics!
Dakota
Old Dec 9, 2015 | 08:52 AM
  #81
Angelo Zani's Avatar
Angelo Zani
352 frankenstein motor
have a 1977 xlt ranger not original motor is the 352 block with D2TAEE heads with 16 screw holes on each exhaut port . block might be or is a service block being the only numbers on block is 4B14 above oil filter and theres a plate on block stating bore .405 rod 1 main 1 and has rib on the out side casting of block ,with street master 390 intake manifold, 4 inch lift 35 inch tire just put a holley 600 cfm on it and readhead steering box borgenson 000975 shaft skyjacker 8000 shocks and skyjacker 7000 steering dual stabilizer
Old Dec 9, 2015 | 03:09 PM
  #82
jujujungle's Avatar
jujujungle
Real Torque Monster
Induction hardened exhaust valve seat. The D2TE-AA came with induction hardened seats and a swirl chamber and the same ports as the C8AE-H and is a better starting point for an otherwise stock hop-up. Check
your seats, prior to 70 the seats hate unleaded so they will not have the hardened seats(better head) this head came on many of the "HIPO" 390's with 3 duces from 58 to 68, the Edsel had a 352 with 4.05 bore(390) but 352 stroke, a very strong engine that would burn all the fuel you wanted to feed it... send them to your local FE head guy... have him port and polish... Flow tech makes the proper headers for this head... low riser intake 3 inch exhaust with X to equalize pressure on the FE with 2 1/2 40 mufflers no more than 3 feet after the X... summit has a nice kit... Gear it properly for the diameter of your tires... use a rev limiter... peak HP should be around 5500 with peak torque at 4800... try for 100MPH at 6000RPM gear ratio
<table border="1" cellpadding="4" cellspacing="0" width="90%"><tbody><tr><td>D2TE-AA </td> <td> 360 390 </td> <td> 2.03/1.56 </td> <td> Note 6 </td></tr></tbody></table>
Grampa jepp
Jul 21, 2018 09:34 PM
rustywheel68
24
Dec 31, 2010 04:04 PM
dj53
Feb 7, 2006 12:50 PM
MKPJ1
Jan 28, 2003 07:17 PM
75explorerxlt
Oil & Lubrication
Jul 15, 2002 12:51 AM
