rebuilt 390 Question
Old Nov 9, 2013 | 07:36 PM
  #61
1972RedNeck's Avatar
1972RedNeck
Originally Posted by HIO Silver
Hmm... I hope the seller stands behind his work or else it's like jumping into a fire... naked.
Depending on the type of material your clothes are, naked could be better.
Old Nov 11, 2013 | 01:34 AM
  #62
stromburg's Avatar
stromburg
Just a little update
Today was a very productive day, I got the entire truck put back together and built the dual exhaust, fired up the engine and got the cam broke in. Hopefully I will take it for a test drive next weekend and report back on the performance of the new engine.
here's a list of what I ended up with:
1977 (early) highboy
NP 435
4.10's
35's
ENGINE:
390 .030 over
H395P pistons .030 in the hole
XE262H cam lifters and springs
Dual roller timing set (I even bought a degree wheel to check cam timing)
D2 heads
Performer intake
Tri-Y headers
2 1/2" dual exhaust thru flowmasters
Duraspark dizzy
Thanks for all the help FTE on my first engine build
Old Nov 11, 2013 | 01:40 AM
  #63
montana_highboy's Avatar
montana_highboy
Not very many guys actually take the time/effort to degree in their cam, most just stick it and forget it....kudos to you.
Old Nov 11, 2013 | 02:36 AM
  #64
stromburg's Avatar
stromburg
I know this is a fairly mild build but I wanted to do everything right and I can't believe how easy is was to use the degree wheel, it only took me about 10 min to verify that the cam was ground correctly with 4 degree's of advance, also an FYI for all the new (to FE's) guy's like me, don't forget to plug the front sump dipstick hole when using the highboy rear sump pan, I got lucky here and noticed it when I was bolting on the oil filter adapter.
Old Nov 11, 2013 | 02:40 AM
  #65
montana_highboy
Seems you did good work for your first FE build.
Don't forget the oil galley plug by the dizzy, that's the number one thing guys forget (I've done it myself)
Old Nov 11, 2013 | 02:42 AM
  #66
rockittsled's Avatar
rockittsled
x2, post your pics
Old Nov 11, 2013 | 02:51 AM
  #67
stromburg's Avatar
stromburg
Between FTE helping me pick the correct parts and Big block ford engines by Steve Christ it went really smooth, the only snag I had was the Holley jet that slid down the hole (which I was able to fish out)and the machine work on the heads was a little off, all the exhaust valves were .010 lower than the intakes valves but luckily the pushrods were the correct length and all the lifter pre-loads check out great.
Old Nov 11, 2013 | 02:55 AM
  #68
stromburg's Avatar
stromburg
Originally Posted by rockittsled
x2, post your pics
I will soon, our dog chewed up my USB cord,so I can't download from my phone.
Old Nov 11, 2013 | 02:56 AM
  #69
montana_highboy
the only snag I had was the Holley jet that slid down the hole (which I was able to fish out).
What size jet did you use (they can't go anywhere btw) most guys use a .60 or .70
Personally, on a street motor with a stock pump (that will rarely see north of 3K rpm) I don't think they're really needed, but it seems to be a popular "fix"
Old Nov 11, 2013 | 03:09 AM
  #70
stromburg's Avatar
stromburg
I used an 80., also a little trick I found for pre-lubing or priming the engine, I used a magnetic bit holder for my cordless screw gun it accepts the 1/4" oil pump shaft perfectly and the outside diameter is the same size as the bottom of the dizzy shaft.
Old Nov 11, 2013 | 03:18 AM
  #71
montana_highboy
also a little trick I found for pre-lubing or priming the engine.
You're already ahead of the curve, some guys don't even do that.....what psi did you see?
Old Nov 11, 2013 | 03:31 AM
  #72
stromburg's Avatar
stromburg
I'm not sure on the oil pressure yet, I am still running the stock gauges, during break-at 2,000 rpm and at full temp my gauge was reading just past the halfway to almost 3/4, I will be picking up some new gauges for the test drive next weekend.
Old Nov 11, 2013 | 03:36 AM
  #73
montana_highboy
Grrr put some real gauges on there, mechanical or electrical, your option (though I highly recommend mechanical)
What bearing clearances are you running?
Old Nov 11, 2013 | 03:37 AM
  #74
stromburg's Avatar
stromburg
I was wondering what spark plugs would be best for this engine with around 9.5 to 1 compression and a durasprk dizzy
Old Nov 11, 2013 | 03:42 AM
  #75
montana_highboy
Autolite AP45's ....with this caveat....
They've recently (like 2009) switched production from the USA to Mexico/China ....so I can't speak to anything current (I have old NOS on hand).
