rebuilt 390 Question
Old Nov 17, 2012 | 01:47 PM
stromburg's Avatar
stromburg
I am picking up a rebuilt 390 Sunday morning and this engine has never been ran, it has also been sitting on an engine stand for 2 yrs. My concern is lubrication for initial fire up and cam break-in since it has been sitting for so long. What would you guy's do?
Old Nov 17, 2012 | 03:02 PM
HIO Silver's Avatar
HIO Silver
Hmm... I hope the seller stands behind his work or else it's like jumping into a fire... naked.
Pull the plugs, spray each cylinder with WD-40, and cycle the reciprocating assembly a few times. Pull the valve cover and check the valve lash. Change the oil. Old stale oil becomes acidic over time. Add some ZDPP. Set at TDC, pull the distributor, and prime the oil system.
For break-in, run the engine over 2,000 RPM for at least 20 minutes then change the oil.
Old Nov 17, 2012 | 03:10 PM
stromburg's Avatar
stromburg
Here are some pics from the ad, it sure looks fresh to me. I will get a closer look in the morning
Old Nov 17, 2012 | 03:13 PM
turbohunter's Avatar
turbohunter
That would scare the livin' crap out of me.
Lot of work and money invested in an unknown.
Personally I'd take it apart while it was on a stand and reassure myself that it's Ok.
Then you could re lube everything.
Old Nov 17, 2012 | 03:22 PM
nine inch rear's Avatar
nine inch rear
Flip the engine on its back, pull a few rod and main bearing caps off and see if assembly lube was used. See that the engine turns over by hand.
If you buy it, make sure the price is right. Your entering an unknown. Spin the oil pump with a drill set up and make sure the oil pressure builds. Do this with valve covers off so you can see the oil is making its way to the top end. Fog the cylinders with light oil before you put in the spark plugs
Old Nov 17, 2012 | 03:24 PM
stromburg's Avatar
stromburg
I was thinking the same thing and from the pics I posted you can see that taking it apart should be simple [it's half way there]. I am getting the engine for $750 so I think it is worth a shot.
Old Nov 17, 2012 | 03:27 PM
turbohunter
Agree.
It would be a bitch to have to pull it all down again after an install.
I think it comes under the "control what you can" rule.
Old Nov 17, 2012 | 03:28 PM
HIO Silver's Avatar
HIO Silver
Ah.. it's long block... I assumed it was fully dressed.
Ask lots of questions! Ask for receipts for the machine work and specs like the cam card, bearings, bore, deck, compression, etc.
Why has it sat around for so long?
Old Nov 17, 2012 | 03:43 PM
stromburg's Avatar
stromburg
He was completely rebuilding a 1972 F100 4x4 and quit on the project. he says that he has tons of new parts laying around like headers, clutch, intake, carb, brake parts etc. I think he had big plans for the truck and got in over his head
Old Nov 17, 2012 | 03:47 PM
HIO Silver's Avatar
HIO Silver
Ah.. in that case, ya might think about buying more of his stuff as a package deal rather than piece by piece. You could come out way ahead.
Old Nov 17, 2012 | 03:59 PM
turbohunter
x2^^^^
His loss is your gain.
stromburg's Avatar
stromburg
Headers and clutch
Old Nov 17, 2012 | 04:02 PM
stromburg's Avatar
stromburg
Header are Stans try-y, they are a well respected local shop and the clutch is a 12" cenerforce II
Old Nov 17, 2012 | 04:03 PM
turbohunter
Careful on the headers.
Lots to think about.
We don't know your truck.
Edit: Just saw you header pic. Just be sure to think ahead as to how everything fits together in your particular build.
Old Nov 17, 2012 | 04:21 PM
stromburg's Avatar
stromburg
My truck is a 1976 f250 4x4, I checked the part Number [244 y] on Stans Headers website and they should fit, it also states that the collectors are lower to clear my crossmember
