390 rebuild question
I am a novice in the middle of a rebuild of a 390. I had a local machine shop build the low end for me about four months ago. I put the heads, timing gear, and pan on then ran out of money due to a few acts of God. So I put in the spark plugs, placed the old intake on just to cover the top end (want a performer), and placed clean rags over the open holes in the intake. Yes I have a bag but it just seems like I stir up more dust putting that thing on and off. Well, now I have the money to finish and was just wondering about the motor sitting for all that time. I am concerned about the moly on the lifters and cam lube. Will all that drip off leaving me without enough protection on start up? Will priming it be enough?
Thanks for the help.
Ken
68 F100 390
74 Bronco 351W
William in Atlanta
He finally bought another car to put it in, and after priming the engine (spinning the oil pump with a big drill) he fired it up. That's been four years ago, with out a bit of trouble. I used the molydisulfide cam lube supplied by Comp Cams. It does not "drip" off anything
.I wouldn't worry about your engine. Just clean it up, finish building it, prime the oiling system and fire it up. Don't bother trying to use a small drill either. I have a 3/8 Craftsman that I bought years ago. I think it cost $25 then, but Wal Mart sells the same thing now for ten dollars or so. I smoked it trying to get my oil pump primed on my 390. Use a BIG drill-1/2 or 3/4, with a big motor!
That's good. The guy with the mushroomed lifters has got me freaked. Playtime could get a little expensive for me if I screw this up. I hope he finds out it was just a poorly ground cam. William, I'm about 130 miles up the road in Greenville, SC. If you are up this way, let me know. Your knowledge is much appreciated in ALL the posts.
Ken
