so they finally found the leak
they said the O ring going from the cooler to the manifold is leaking
i think i said that right
so what would it hurt to leave that for a while and just keep an eywe on my coolant level?
remember i am having #5 injector replaced
No, repair it promptly, there is no coolant level gauge, you could drive tomorrow and it gives up the ghost, leaks coolant and your motor overheats and now you need a long block for 13k, if you know about it, fix it.
so i had the injector replaced and the white smoke problem is gone
i was going to wait till spring to do the egr but with it leaking around the oring im afraid could get worse without me knowing so next week im having the oil and egr cooler replaced
there is a very well recomended mechanic here that checked it out and the only moisture he could find was around the oring
he said the hose was not leaking
I have tried on 2 occasions to buy parts from Cobb's Diesel Performance in Lenoir City, Tn. First order was lost and had to stop pay on credit card, reordered on Nov,30 and no confirmation on order but card was charged the next day. FYI only
Is it where the coolant pipe attaches under the manifold? When I put in my delete I remember putting a lot of JB weld on that fitting, I was scared that it being under the manifold I would have to remove everything again if it leaked.
yep that is where he showed me on one he had out.its not leaking bad but i am afraid to chance it
i cannot afford to do the bullit proof oil cooler so what i pland is the ford oem oil cooler and i guess the egr delete
is there a better oil cooler for about the same price?
well i have bit the bullit and replacing the oil cooler ,egr cooler, some kind of upgraded snap ring fitting .coolant flush and oil change
i have not had any super high deltas so just doing a flush and fill on the coolant
sound good?
