NEED HELP A.S.A.P
Old Oct 28, 2010 | 08:39 PM
MonkeyBoyTX9's Avatar
MonkeyBoyTX9
NEED HELP A.S.A.P
ok i have white smoke comeing out of the exaughst there was no antifreez in the tanks and it did get hot on me 1 time i was pulling a 4000 lb trailer never lost power just white smoke and it got hot need any info i can get and it i disconect the egr will i still have to replace the egr cooler that is my main question the mec says egr cooler is leaking but i am not a mec so i dont know we just baought the truck used so no warenty
Old Oct 28, 2010 | 08:44 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Unplugging the EGR valve won't help you a bit. You're going to have to replace the EGR cooler and the oil cooler.
Old Oct 28, 2010 | 08:45 PM
moebdick's Avatar
moebdick
Very likely the EGR cooler is leaking, probably because the oil cooler is restricted and caused it to overheat. Smell the smoke and see if it smells "sweet" like antifreeze.
Old Oct 28, 2010 | 08:59 PM
MonkeyBoyTX9
it smells sweet so egr cooler and oil cooler how much do ya think it will cost in labor
Old Oct 28, 2010 | 09:16 PM
fatcowvtx's Avatar
fatcowvtx
300 for oil cooler parts, buy a bullet proof egr cooler, look for links to web site. around an 8 hour shop time (50 -85) an hour. put on a coolant filter, this is a must!!!!!
Old Oct 28, 2010 | 09:21 PM
redrock233's Avatar
redrock233
Its not that hard to do the whole delete yourself. Including the oil cooler. there are so many people on here to help with any info you might need. The best thing i got out of this thing is i know now a lot more about the engine. Look in the tech folder
Old Oct 28, 2010 | 10:52 PM
High Binder's Avatar
High Binder
Do it yourself, I just finished doing the EGR block-off and new oil cooler took me a while but saved a ton of $
Old Oct 29, 2010 | 06:58 AM
bismic's Avatar
bismic
Don't keep running it that way, you can do a lot of damage!
Old Oct 29, 2010 | 09:26 AM
MonkeyBoyTX9
nope
the truck is parked till we can get it to the mech i hav f350 i own my uncle owns the 250 so he is a little pissed just baought it and drove 700 miles and this **** happend it happend on the last 1 mi or so so havent driven it much since maybe 3 miles like this but we will have to take it 20 or so to the mech can we drive it there?? please let me know thanks
Old Oct 29, 2010 | 09:33 AM
moebdick's Avatar
moebdick
I would not drive it that far. Coolant could get into the cylinders and could hydrolock it.
boudrow75
Jul 8, 2019 02:41 PM
sewerratbob
Aug 26, 2014 07:35 AM
lil ford mec
Dec 21, 2013 07:25 PM
devildog12210
Aug 23, 2010 09:40 PM
