alt guage problems
Old Nov 16, 2012 | 11:34 AM
fmc400's Avatar
fmc400
MSEE
Originally Posted by buttwheat
I'm not sure why you all say an ammeter is useless? If the meter is working correctly it is very useful showing you whether the electrical system is charging or discharging by measuring the amps going through the wire. Where a volt meter is simply showing you the amount of volts in the system with no way to tell you whether your charging or discharging.
The ammeter is useless because it is a shunt-style ammeter and therefore has very coarse resolution. You cannot use it to monitor minute changes in the charging system's output because it is masked by the coarse swing of the needle. The total current in or out of the battery is not what the ammeter measures; it only measures a very small portion of it through a secondary smaller wire (hence the name "shunt").
An ammeter is not the proper tool to monitor a charging system. Obviously it's useful to know if a system is charging or discharging, but that is only relative information. Watching an ammeter tell you it's discharging does not tell you how close the battery is to depletion on an absolute scale. This is something only a voltmeter can tell you.
Contrary to your claim, a voltmeter can tell you if the system is charging. If the voltmeter reads below the battery's steady-state voltage of 12 volts, it's discharging. If the voltmeter reads above steady state, it's charging.
Because voltage is what the voltage regulator uses to regulate current into the field terminal and control alternator output; voltage is what you want to be looking at anyway when diagnosing charging system issues.
Old Nov 16, 2012 | 01:01 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
And that is the definition of getting *owned.
Thanks for putting it out there FMC400
Josh
Old Nov 21, 2012 | 11:33 PM
buttwheat's Avatar
buttwheat
My bad on that. Being a licensed electrician my brain gets stuck on AC power with an unlimited supply of electricity. Of coarse with a limited supply of electricity as your using more wattage then your producing you will have a voltage drop.
Josh
What are you twelve?
Old Nov 21, 2012 | 11:40 PM
Bullitt390's Avatar
Bullitt390
A 12 year old that fully understands automotive electronics apparently.
Josh
Old Nov 21, 2012 | 11:46 PM
buttwheat's Avatar
buttwheat
Josh
Dude not looking for some sort of argument just seemed a little childish to me thats it.
Old Nov 22, 2012 | 12:31 AM
Riderman's Avatar
Riderman
I put a "new" entire dash\instrument cluster out of a late eighties ford van in my truck last month. The ammeter needle moves between midway and 3/4 of the charging side of the guage at night with the lights on while driving, and back to center while idleing. It moves about 1/8" total from center deflection during the day while driving. By that I mean, it goes to the right about 1/8" and back to center while depressing and letting off the gas pedal after start up and before the battery is fully charged.
I love it, just because the needle moves.
Old Nov 22, 2012 | 08:24 AM
fmc400's Avatar
fmc400
MSEE
No worries. I have the same issue when I switch gears and go from working on the truck to working on the house.
kamloops
1997 - 2003 F150
Apr 26, 2008 11:35 AM
rmalottwtes30
Mar 9, 2008 06:33 PM
vicnation
Dec 10, 2006 01:44 PM
TheRealMongo
1978 - 1996 Big Bronco
Oct 13, 2004 02:55 PM
rabidranger
Jun 19, 2002 08:47 PM
