Idiot Voltage Guage?
Old Jun 18, 2002 | 05:39 AM
rabidranger's Avatar
rabidranger
Is the voltage guage in my 97 F250 HD a idiot guage, or does it read the ACTUAL system voltage? Just curious, because it never moves, just points dead center.
Old Jun 18, 2002 | 07:34 AM
winfordr's Avatar
winfordr
Should be a real volt meter. If it doesn't move at all, it is probably stuck.
In the old days, there were ammeters, which were really voltmeters reading a small voltage drop across a very low resistance. These would stop working because of corroded contacts, or various other reasons. They actually measured the voltage drop across a section of the wire between the alt and battery.
But if the meter is a volt meter, it should read battery voltage directly, and should deflect when the lights are switched on and off without the engine running.
Winford
Old Jun 19, 2002 | 05:46 AM
rabidranger
It will drop down to 8 (lowest point on guage) when the engine is off, but then jumps right to the dead middle while running. Same with the oil guage. I know the oil guage is an idiot guauge, but I just wondered about the voltage one as well.
Old Jun 19, 2002 | 03:05 PM
brown 4x4's Avatar
brown 4x4
Every 92-96(7) truck I've seen had a "real" one. You should really notice it move if you run the power windows with the engine off.
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Jun 19, 2002 | 08:47 PM
MustangGT221's Avatar
MustangGT221
