H&S Performance suspends production of all products
#123
I could point you to oil fields in the middle east or Russia that are unmitigated environmental disasters and argue that based on that what companies are doing in North America is insignificant and doesn't really matter.
The problem with those arguments is that two wrongs don't make a right. Just because little Timmy across the street is doing it doesn't mean that we should or that it's OK to do.
The oil well needs to be XXX meters from a water well, think that does anything for anyone? Aquifers travel for miles and miles.
That's why wells are drilled with fresh water until they've reached a depth below ground water and then have casing cemented in place to prevent any contamination during the drilling process or production. It's why leases are built the way they are and why on lease spills and contamination have been all but eliminated and are strictly regulated.
I realise oil companies "donate" money for environmental studies.... so do cigarette companies donate money for research..
I can give many examples of environmental travesty examples that follow regulation, but it would be a PM thing for anyone interested.
If you want diesel for that truck of yours, that comes with the territory.
#124
Yes, I do, and the oil industry's record proves it. I know you can point to a few exceptions, I can too, but there are 10s of thousands of oil wells in Alberta and 100s of thousands in NA that have been drilled without issue.
Saying "there are xxx amount of wells drilled without issues" is like saying "I know xxx amount of people that smoke and are healthy."
I know of plenty of issues and disasters.
When you frac, you create a pathway between 2 or more formations, and you can't control the frac with certainty.
Lots of fracs end up connecting hydrocarbon bearing formations with ground water bearing formations.
Without going into specifics, there are companies now that don't even pump enough cement to return back to surface on the outside of the casing.
And that casing and cement we speak of, it doesn't last forever, either.
In the presence of H2S, it degrades quickly, and sometimes stainless steel casing is used, but rarely, I heard it was 20k$ per joint.
#126
People cross the street by the millions every day, when done properly, it's a very safe thing to do and poses no risk to the person crossing the street or the motorist, however, unfortunately, despite this fact, people do get killed crossing the street.
You're right, it doesn't last forever, and that's why throughout the producing lifespan of the well it's constantly tested, pressure checked and repaired as necessary. When the casing is beyond repair or a well is finally abandoned, the wellbore is filled with cement and plugged off to prevent cross-flow. This cement and casing combo is every bit or more effective than the natural barries to vertical migration.
#127
stop reading the commy govt hand book. Save the world. Just sell your tuck move to California and buy a govt motor volt go charge it off if a wind mill. Stop using anything that comes from Fossil fuels. I'm tired of Hearing about how bad oil company's. EPA and The media are really quick to take an Accident and make sound like it the end of the world. Greece 2 America's turn.
#128
No, actually it isn't. It's demonstrating a long standing safety record based on industry practices.
I would disagree with you. Damages are constantly down played or avoided, not prevented.
This is partially true. Frac's rarely extend beyond specific formations or porous zones within those formations. There are no guarantees, but industry has a pretty solid understanding of the physics and mechanics behind fracing, they know with a pretty good degree of certainty where those fracs are going. It's a pretty essential piece of the puzzle to understand.
Fracs are tricky, you can control to a degree where they go, but you can't control where they stop. To put emphasis on the crap that guys get away with, a company pumped 10 times what the plan was, into a formation, and caused a lot of damage and never got fines or anything. Right into the aquifer.
This statement is simply false.
Um no it's not. BTW you can't just google this type of information. You pretty much have to be in the field or know guys to even know about it.
Again, you're pointing out that companies that break the law, and therefore the laws and their intentions are not valid. That's not a credible arguement.
Hardly what I would consider ideal, but it was all that was legally required.
This is just a little snippet i stole :
In many of the older fields previously abandoned, many of the wells were potentially left unplugged and their locations not
properly documented (Pennsylvania DEP, 2000). As these old fields are reentered to apply newer technologies such as solvent or CO2 flooding, the reservoir pressure is increased due to the injection of fluids for oil recovery. When this higher pressure is applied to unplugged or poorly
plugged wells, there is a chance that the formation fluids will bypass the plugging materials and migrate uphole. This can cause problems with the fresh water aquifers in the area by allowing gas, oil or salt water to contaminate the fresh water.
#130
I guess we'll have to agree to disagree on this one. I see first hand everyday the lengths and expense we go to in order to prevent damage. Simply put, you can't have your cake and eat it too. If you want fuel for your truck, it comes at a cost, there is an impact, but I do see the positive results of increased regulation in minimizing that impact.
Again, not really.
The first factor is the reservoir itself and all the parameters associated with that (composition, porosity, permeability, etc...) and then the actual physical size of the reservoir and it's bounding lithologies. With that info, the frac size, fluid type, concentration, pumping rate, etc... can all be manipulated to control pretty precisely where that frac is going both vertically and laterally. It's big money and big science to understand this stuff, it's critical to well performance, well densities, etc.... and that's critical to the bottom line.
I don't put a lot of stock in "company z pumped 10X more than they should have and ruined an aquifer" type statements. In 15+ years, I've never seen or heard of it. I know the costs and issues involved, and it simply doesn't make sense.
That said, I don't doubt it might have happened somewhere sometime, but like I keep repeating, one bad apple doesn't spoil the bunch. With thinking like that we'd have all blackballed Ford and banned the sale of the 6.7 after Rickatic's issues.
You're exactly right, you can't just Google this, you also can't believe every bit of gossip you hear floating around the camp or the internet. I work with this every day, hands on, and have personally overseen the drilling and frac'ing of hundreds of wells. I've been involved in companies that have drilled thousands of wells. There's been 10s of thousands of wells drilled in AB Canada in that time frame, and I'm not aware of any wells that have frac'd into an overlying freshwater acquifer. It's a myth created by those who don't understand what frac'ing actually is or how it works.
Again, I don't doubt that there are a couple places in the USA, where regulations were (are) more lax, that acquifers have been damaged in the past. That does NOT mean that it is in any way common or a legitimate risk when frac'ing is done properly.
The last
well I remember abandoning was excavated around, and cut off and buried, and there was a packer set inside.
In some ways I guess the son is guilty of the father's crimes.
Legacy oil fields from pre 1970's are an issue, especially those from the 50's and 60's when records of what when are let's say, less than complete. Industry in AB has set up an "orphan well" fund, by which a percentage of all revenue is held back and used to pay for the remediation of improperly abandoned wells from these oil fields. It's costly and messy, and not enough is being done fast enough, but the work is getting done.
Fortunately, we've learned a lot since then, and the new regulations in place will prevent the same thing from having to be done in 50 years time from now.
Originally Posted by HDSlider
Dang all this for H&S stopping there tunes. Shew.
#132
#133
We obviously don't agree on some things, no point in having a little flame war...
There are a lot of people that would take either side of our opinion, so likely an argument that would never end lol.
#134
Not exactly, but I get what you're saying, and bridge covered it.
At any rate, it took millions of years to sequester the carbon we've returned to the environment in the last 100 years. Nature is incredible in it's ability to adapt and continue on, but it doesn't work on our human time scale.
I don't believe 95% of the global warming and climate change nonsense out there, but I do understand the basic facts of how we're altering the environment and the effects of toxins, and that leads me to believe that our actions do/will have both long and short term consequences of some kind. How could they not? In addition, many of the worst contaminants are not "natural" in their occurrence, and just how they'll affect things long term is not known, it can't be at this point.
The truth lies somewhere in the middle. It's not catastrophic like the green extreme Al Gore types would have you believe, but it's certainly not non-existant either. We have the scientific data on this, we have the real world experience and analogies to back it up, and we have simple common sense.
I dislike beauracrats and lawyers as much as the next guy, they're an unfortunate reality that comes with any kind of government or regulation. If you want to talk no real value added, that's where you start. However, that doesn't negate the need for regulation, or the positive aspects it creates. I'm not sure what the ultimate objective of the EPA is, but to say that it has failed to accomplish the objective of cleaner air and water would be pretty blatantly false.
Now, if you take those people that refuse to accept the status quo and limitations and have them innovate new solutions within the framework of the law, well, to my mind, and like bridge has stated, that's where the true value and advancement comes in. Necessity breeds invention as they say, and I could point to a lot of positives that have come from EPA regulations that I once railed against. (The 2 stroke engine being the best example. It was supposed to die with the 2006 emissions regs, but instead, it finally saw real advancement and is now light years better in not only emissions, but performance than it was for decades before the regulations were put in place.)
I'm stating that I'm not only passionate about a lot of things that have an impact on the environment, but I make my living from it. The key is, I'm aware of it, and I do realize that some regulation on these things in favour of environmental protection is not only good, but necessary. The point I'm making is that the two sides of equation do not have to be mutually exclusive.
Carl
#135
As far as ground water and formations go, there are many things we don't know.
There are lots of theories, lots of evidence and proof, but weird things continue to happen.
There are many formations that are water bearing of some type, many of these can be really close to oil bearing formations, and many of them actually FLOW!
That is to say, they don't just sit there making sand wet, the are moving from "somewhere, to somewhere else".
An example of this I know of is the huge underground "lake" that plagues the potash mines in Saskatchewan. The cores look like giant worm burrows, and it flows with salt water.
I can't remember the exact depth, but I'm thinking around 900 meters.
So if oil wells somewhere around that formation lose oil into the water formation, where does it go?
When test holes get drilled with invert mud (diesel or mineral oil), where does it go?
It's flowing, so it goes somewhere!
This is just what I mean we don't know enough.
