H&S Performance suspends production of all products
#226
#227
I would think that H&S would have to be a little more careful about that kinda thing now, but maybe not.
#229
#230
#231
on
Thanks Gavin, I am going to check a few things out before I spout off again......
NADP says, on the current tuners, you just select "high sulphur" instead of DPF off and do not need any special application or code etc. It is the same a DPF off but just sounds better (I guess). The new street tuners will require you to fill out the application for "high sulphur" or DPF off......
That's all I know right now
![Smilie](images/smilies/happy0161.gif)
Thanks
Thanks
#232
So after reading all this about the "new" tuners H&S offers, are they still able to sell the Complete Delete Tuners? Or has the EPA forced them to go with the DEF tuners?
I havent had the time to order my DEF delete Tuner yet, but am I wasting my time and money on a DEF Delete Tuner? Darren was talking about H&S isnt offering the downloads now? Is this all true?
#233
on
D it looks like I opened my mouth too soon as usual. I need to do a some more research but the way I see it now.....
If you have a current "delete" tuner H&S is still supporting and updating. Some changes in terninology like "high sulphur" instead of "DPF off".
The new street tuners are DPF on only unless you fill out and application for "high sulphur" then I woudl think you get some kind of code to unlock the DPF off capabilities.
As I get more information I will keep you posted.
Thanks
Thanks
#234
At some point you are going to need to make time to order an original MiniMaxx as they are really hard to find now and are getting more expensive.
#235
Read the thread? No, H&S has stopped selling DPF delete tuners voluntarily (no doubt because of strong harassment by the EPA, but the EPA never shut them down). It appears that H&S is going to continue to offer DPF delete option, but is renaming them High Sulfur racing options and will require formalized proof in order to obtain them in the US. Form is likely to include proof of a non-registered vehicle and racing application. I'm speculating, but I don't think this affects Canadian customers, but they will likely still need to complete a form proving residency or something along those lines.
So, they will still offer downloads for DEF delete Tuners? Or will current Downloads on the DEF delete tuners work forever?
Sorry guys for the stupid questions, or lack of knowledge on the tuner subject as Im a NEWBIE. So, please, BE GENTLE.
#236
Thanks
Thanks
#237
on
It looks like the "high sulphur" application for the street tuners is not going to be an easy thing (at this point). But I bet it gets a lot easier as time goes by
![Wink](images/smilies/wink.gif)
I have almost every TV for the black maxx and will keep them all.
I am going to get every TV for the minim maxx I can and keep them as well. The mini I have now is just for a backup for me but I want to be able to use it if I have to. That is why I posted when I mistakenly thought H&S latest update did not support DPF off tuning. I was wrong on this. It still supports DPF off tuning, it just calls it high sulphur. Sorry for the confusion.
Currently I am on black maxx TV 6.7.24 (4 behind the current version) and staying there indefinately. Everything is working perfectly.
#238
If I were a betting man, I'd say you will still be able to buy high sulfur rom (tunes) from a non-US based distributor when the heat dies down or rely on someone like Darren to have your back. Bottom line, keep back ups of your files redundantly. Don't allow your truck to be reflashed by Ford unless absolutely necessary. I don't see the guys that have current H&S MM's and BlackMax's getting stuck with paper weights ever. H&S just isn't that kind of company. Nothing they have ever done has suggested they would leave you stranded. I would expect more information to trickle out between now and the 21st of Jan.
#239
mini maxx lastes update.......
6.7.27 Jan. 6, 2013 – Firmware 1023, DPF delete modified to High Sulfur text, Log files added, Auto detect firmware update added, SD card communications updated, Stock files removed from basic download to increase update speeds, Power level names changed – Stock, Tow, Street, Performance
WTF does this mean??
If you update your mini you can't use it for DPF off anyomre???
I have all the black maxx files but went to update my spare mini SD card and saw this.
Guess I will need to get an older version of the software somewhere.... Andrew, buddy, I will send you soem cash![Smilie](images/smilies/happy0161.gif)
I will call NADP and see what they say
Thanks
Thanks
I have .19 on my card. I can send you a copy no problem.
I saw no reason to update any further unless you wanted the low boost fueling thing. I like the smoke and stayed at .19
