H&S Performance suspends production of all products
#196
Is it possible that buying a tuner right now without this new emission limit would stay a non emission unit with the updates after January 21? The before and after tuners should be the same, just the software on it different? Which may mean buying a tuner now and then never update it?
I'm not sure buying a unit now and hoping it runs on new trucks is a sure fire decision.
#197
on
What happens if Ford changes something on the truck that requires H&S to tweek their programing. Since they are no longer developing new software for the delete units. Would you be SOL?
![Smilie](images/smilies/happy0161.gif)
#200
Let me ask. But in the past. If you went in to buy a pcm/ecm. You had to give them yours and then it would get sent back to ford for them to install correct miles on truck then send it back. Now im not sure how they do it today. Maybe let tech do it with ids. Or maybe body module would store it. As well as intrement cluster. Darren do you remember how they done it on yours, when they replaced yours at the dealer.
#201
#202
#203
#204
on
I have never returned to stock. I have taken my truck to the dealer tuned many times and I said f the warranty at 5,000 kM. My dealer has been pretty good with warranty on non engine related stuff so far.
#205
#207
on
![Spanking](images/smilies2/spanka.gif)
![Missing Teeth](images/smilies/missingteeth.gif)
Anyway they were good and le me re program the ECM in their bay. The tech was pretty interested in it and wanted to lear how it all worked.
FYI, if you return to stock withou DPF EGR cooler etc the truck starts and runs for about 3 second then it is totally dead. Will not even turn over. I could not even could the number of CEL codes on the screen.
![Shaking Head](images/smilies2/rotz.gif)
#208
The other factor that I think deserves to be taken into consideration...H&S's reputation. The EPA is watching them. They wil lnever admit to doing anything publicly, but I'd have to think if one of their products caused an issue with your truck, they will do everything in their power to get the issue resolved. You just need to use a little common sense and contact them properly and discreetly. Go whining on a forum and see how fast you get ignored...
#209
Yes, like when I took my truck in for the battery light and told them NOT to flash it. Then they called and said my truck is dead in their bay.
I said "I told you not to flash it". They said "we had to flash it cuz we put a new ECM in it" ![Missing Teeth](images/smilies/missingteeth.gif)
FYI, if you return to stock withou DPF EGR cooler etc the truck starts and runs for about 3 second then it is totally dead. Will not even turn over. I could not even could the number of CEL codes on the screen.![Shaking Head](images/smilies2/rotz.gif)
![Drink to That](images/smilies2/party0005.gif)
#210
on
mini maxx lastes update.......
6.7.27 Jan. 6, 2013 – Firmware 1023, DPF delete modified to High Sulfur text, Log files added, Auto detect firmware update added, SD card communications updated, Stock files removed from basic download to increase update speeds, Power level names changed – Stock, Tow, Street, Performance
WTF does this mean??
If you update your mini you can't use it for DPF off anyomre???
I have all the black maxx files but went to update my spare mini SD card and saw this.
Guess I will need to get an older version of the software somewhere.... Andrew, buddy, I will send you soem cash![Smilie](images/smilies/happy0161.gif)
I will call NADP and see what they say
Thanks
Thanks
