Over the past few weeks I have been noticing my icp has been jumping up to around 950 or so after a cold start and then slowly works its way back down to around 600 ish. Koeo is 2, cranking is around 350, and starts within 2-3 secs then gets 950 then back down to 600ish after warm up. It only does it on a cold start. the rest of the day is normal start then 600ish. I have AE but have not yet watched it on a cold start only the SG2. Otherwise vehicle runs fine. I also have the refresh rate on SG2 set to fast.
I was wondering if the colder weather had anything to do with it. Since i have only owned the ex since aug I don't have a baseline for behavior in cold weather yet.
