Missing bad and lost power
Old Dec 1, 2012 | 08:15 AM
  #181
oldbird1965's Avatar
oldbird1965
Yes he did Nate.
Old Dec 1, 2012 | 02:16 PM
  #182
ReBilld's Avatar
ReBilld
The truck is running like crap this morning. Started it up and had the smoke and the usual stuff, then it started running real rough, When I rev it as described before, lots of bluish smoke. I unplugged both driver's side UVCH plugs, rev it, and no smoke. I took the solenoids off the driver's side injectors, and found that two of the solenoid spacers were turned 180* different than the other two. I don't know if it matters or not, but with the two turned opposite of the ones in this diagram, it puts the spacer several thousandths closer to the armature plate. Does any one know if this would matter?
http://inlinethumb47.webshots.com/44...600x600Q85.jpg
Old Dec 1, 2012 | 04:45 PM
  #183
fordpride's Avatar
fordpride
I'm not sure but I'd put them the way they are supposed to be
Old Dec 1, 2012 | 05:32 PM
  #184
ReBilld's Avatar
ReBilld
I took the solenoids off the pass. side too, and some of those spacers are turned different too. It's like they were alternated, one one way, and the next one the other.
Old Dec 1, 2012 | 06:24 PM
  #185
oldbird1965
Alians and electrical gremlins, damn!! (sorry, I'm not much help)
Old Dec 1, 2012 | 06:33 PM
  #186
ReBilld's Avatar
ReBilld
Yeah, and it couldn't have done this back in the spring when I bought it and had money saved up and was working lots of overtime! LOL!! It had to wait until I was broke to do this LOL! That's the way it goes though.
Old Dec 1, 2012 | 06:45 PM
  #187
Action4478's Avatar
Action4478
Did you verify the poppet screws were tight?...Did you measure them ?...
Old Dec 1, 2012 | 06:55 PM
  #188
ReBilld's Avatar
ReBilld
I can turn the armature plates, but they don't spin real easy. I don't have anything to fit the poppet screws, so is trying to turn the armature plates a good test to see if the screws are loose. I checked the ones on the driver's side with a feeler gauge, and .003 goes in very good. Just barely can't get the .004 in there. I haven't checked the pass. side with the feeler gauge. Rick, why would some of the solenoid spacers be turned the opposite way?
Old Dec 1, 2012 | 06:57 PM
  #189
Action4478's Avatar
Action4478
If you can turn them , the screws are loose ...
Old Dec 1, 2012 | 07:02 PM
  #190
ReBilld's Avatar
ReBilld
So if the screws are as tight as they should be, then I should NOT be able to turn the armatures any at all with my fingers? Is that correct?
Old Dec 1, 2012 | 07:30 PM
  #191
Action4478's Avatar
Action4478
You should not be able to turn the armature plate with your fingers...
Old Dec 1, 2012 | 07:52 PM
  #192
ReBilld's Avatar
ReBilld
Should I order the Nintendo tool off ebay and tighten the screws? The poppet screws can't be what's shutting the driver's side bank is it?
Old Dec 1, 2012 | 08:17 PM
  #193
Action4478's Avatar
Action4478
If the screws are loose , you need to tighten them . I hear the Nintendo tool is what you need
Old Dec 1, 2012 | 08:24 PM
  #194
ReBilld's Avatar
ReBilld
I'll get one as soon as I can. What about the solenoid spacers being turned different, why would they be like that? Shouldn't they all be the same?
Old Dec 1, 2012 | 08:34 PM
  #195
Action4478's Avatar
Action4478
I don't know what to tell you about that , maybe Jim knows ...
