Brake Compression Sporadic / Gone ..
Old Nov 9, 2012 | 05:23 PM
oldfords4me's Avatar
oldfords4me
hey all ...
My 76 F 100 power brakes seem to be having some issues. If i pump the brake a lot, the compression comes back for a second or two, but that's about it. Have to press it all the way down to the floor now. Can't seem to locate a leak and the fluid level seems to stay consistent.
1. Bad/leaky hose somewhere?
2. Bad MC? Bad Booster?
So, not sure what i should do at this point. Any assistance/opinions would be appreciated. Thank you All!
Old Nov 9, 2012 | 05:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you're not losing fluid then you don't have a leak. In all probability it's going to be a bad master cylinder but the first thing I would do is check the adjustment on the rear shoes.
Old Nov 9, 2012 | 08:39 PM
oldfords4me
Thank you. I have a little fluid loss maybe, after looking at it today, but its just not that much ... What do i check 'adjustment' wise? They are drum brakes ..
if it is the MC .. is there a way that I can tell that it is that?
Thanks again!
Old Nov 9, 2012 | 08:51 PM
devino246's Avatar
devino246
Thanks again!
Pull the wheels off and spin the drums. Properly adjusted, you'll hear a very faint scraping sound as the shoes lightly rub the drums. If you don't hear this (and you probably won't), pull the drums off and turn the starwheel a few clicks. Put the drums back on, check for light dragging. If they're lightly dragging now, you're all done. If not, continue adjustment until they are.
"starwheel" is the thing near the middle of this picture that has little teeth on it.
However, if you have any fluid loss, you're sucking air into the system when you let off the brake pedal. Fix the leak first, and bleed the brakes. When it comes to brakes, no leak is acceptable.
Old Nov 10, 2012 | 03:02 PM
oldfords4me
Thank you! .. I will try this first ... after i've exhausted my options in finding a leak if there is one. Thanks again, very helpful!
Old Nov 10, 2012 | 07:18 PM
devino246's Avatar
devino246
No problem. Let us know how it goes.
Old Nov 10, 2012 | 10:13 PM
Jigger2020's Avatar
Jigger2020
Good luck with all that ............
Old Nov 15, 2012 | 01:24 PM
oldfords4me
so its leaking after all i have found. passenger rear tire...going to take the tire off and see hat's going on with it..
flip4eva83
18
Oct 10, 2012 01:49 AM
meborder
Jul 16, 2012 10:27 PM
tikkakoski
Mar 1, 2011 08:23 PM
bassproguy07
Apr 7, 2006 07:43 PM
lizziesmom902
Aerostar
Feb 22, 2005 11:03 AM
