injector pump tuning
Old Nov 19, 2012 | 04:08 PM
  #46
joshofalltrades's Avatar
joshofalltrades
don't mess with the throttle stop. its probably there for a reason. if you want to increase the maximum fuel output, there is an adjustment screw under a little cover on the side of the IP. thats where you want to make your adjustment.
its a little triangular cover, i'm sure someone here has a pic of it, i've not adjusted mine, but i think i identified it on my spare IP - but i'm not sure enough to point you in the wrong direction
Old Nov 19, 2012 | 07:05 PM
  #47
1989f250IDI's Avatar
1989f250IDI
Anyone else?
Old Nov 19, 2012 | 09:14 PM
  #48
1989f250IDI
The throttle stop is adjustable. It has a bolt and a nut for a stop. It is meant to be adjusted
Old Nov 19, 2012 | 09:44 PM
  #49
RacinNdrummin's Avatar
RacinNdrummin
The throttle stop is just going to minimally give you a bit more RPM, just puts more pressure on the Gov spring and holds the metering valve open a little further. If you want more RPM, than you can adjust it (only about a 1/2 turn at a time, then test), but if you are just looking for more fuel on the lower end, it wont give you anything.
My truck for example, uses the whole sweep of the cable, I set it like that to get as much metering valve travel as possible... Its not necessary on a DB2, as the metering valve flows plenty for that in stock form.
A better way to get more RPM, if thats what you are after, is to adjust the Gov stud just above the head (part where the injection lines go on)...If you turn it in, it will give you more RPM...
Old Nov 19, 2012 | 09:48 PM
  #50
1989f250IDI
I think i found what you are talking about. Does it have a cap on it?
Old Nov 19, 2012 | 09:54 PM
  #51
RacinNdrummin
Most likely... Thats an Anti-tamper cap, if you have a pump warranty, dont remove it lol...
Old Nov 19, 2012 | 10:37 PM
  #52
1989f250IDI
My pump is original lol
Old Nov 20, 2012 | 03:36 PM
  #53
brads93 idi's Avatar
brads93 idi
Ok do screwing the screw out does away with the gov of fuel u get but screwing it in gives u more ???? I think I didn't comprehend what yall where saying on that
WarOzz
18
Jun 20, 2010 08:05 PM
rmalottwtes30
May 7, 2008 02:43 PM
mudracin74
General Diesel Discussion
Mar 7, 2007 07:43 PM
86turbo
23
Aug 31, 2006 02:26 PM
motovert2001
Jan 7, 2005 07:12 AM
