Should be OK if you do small increments and make sure you know where the OEM mark is right now so you can still go back to the original setting. Go in 1/16" incriments at the most and retest to see the result. And don't run the truck without IP bolts tightened, make the adjustment, retorque the bolts and then restart the engine.
