Engine swap - Flywheel problem
Old Nov 4, 2012 | 07:57 AM
asghert's Avatar
asghert
I have a 79 swb column shift. I replaced the 302 not long ago with an 86 HO that I rebuilt. I matched the front balancer, but in the end the bell housing is too large to run the smaller diameter flywheel that the 86 HO takes. In other words my starter won't line up. Someone told me to try the same year flywheel for a truck and that didn't work because I'm still feeling a vibration at about 1600 rpm.
I want to keep the column shift. Is there anything I can do? Are there specialists out there that can balance the weight on the flywheel? Does an 86 bell housing bolt to the 79 3 spd transmission?
Thanks!
Old Nov 4, 2012 | 09:35 AM
jacks61ford's Avatar
jacks61ford
use a Windsor flywheel in the correct tooth count for your application the balance is right and it will fit your truck
Old Nov 4, 2012 | 10:03 AM
asghert's Avatar
asghert
I think that was the same flywheel I had on it initially. I used the one from the old motor, then swapped to the newer model. When I cross reference the Windsor and the 302 it looks like the same one. Am I missing something?
Old Nov 4, 2012 | 10:05 AM
asghert's Avatar
asghert
Starting to wonder if the flywheel isn't the problem.
Old Nov 4, 2012 | 10:17 AM
jim collins's Avatar
jim collins
You need a 50 oz. balance [164] tooth flywheel,not 28oz. which the 351 w is. Ford changed the 302 to 50 oz. in 81 ,but left the 351w at 28 oz. Been there and done that. I have a 85 302 in place of an older 302 and had to change to the 50oz.
__________________________________________________ ___________________________________
EDIT--I just went to the shop and checked the extra flywheel i have for my truck, just like the one in it.
It is 14 1/4" ,with 164 teeth. Ford part number--E1TE-AA .
Old Nov 4, 2012 | 01:55 PM
jacks61ford
I thought Windsor was 50 oz
Old Nov 4, 2012 | 02:55 PM
jim collins
No , just google it.
Old Dec 24, 2012 | 09:37 AM
JWC 3's Avatar
JWC 3
I put an 84 302 in my 78 . I was always a gm guy. It drove me crazy finding the vibe . Finally an old ford guy set me straight . I had to change the flexplate and balancer to take care of it .
junkyarddog82
Feb 12, 2008 09:53 PM
astroriley
Feb 21, 2004 07:04 PM
Txquadhunter24
Aug 24, 2003 06:37 PM
amtocco
Aug 22, 2003 08:04 AM
F100clark
Jun 5, 2002 10:09 PM
