flywheel help
Old Aug 21, 2003 | 10:07 AM
amtocco's Avatar
amtocco
flywheel help
hey everybody, i have a 86 crownvic fuel injected 5.0 that i'm installing in my bronco. the engine came with a auto tranny and i want to bolt up a bw t-18 4speed. does anybody know a part no. for a flywheel that i can use on this engine? also, is there a way to tell if the flywheel and balancer will match? i need to make sure the standard shift flywheel matches to the balancer the same way the original flywheel did. any help is appreciated.
Old Aug 21, 2003 | 12:25 PM
ecarter50's Avatar
ecarter50
flywheel help
I don't know the part number but the flywheel you need is for 82-later 302 which is 50oz imbalance. Match the flywheel to the engine not the balancer. Use the balancer that is on the engine.
Old Aug 21, 2003 | 05:44 PM
i_alone's Avatar
i_alone
flywheel help
E1TE-AA, I know this because I ran into a problem with Flywheels and imbalance problems, E1TE-DA is for a 351
Old Aug 22, 2003 | 08:04 AM
amtocco's Avatar
amtocco
flywheel help
thanks for the help guys. i'll probably end up buying one from summit racing or wild horses. just wanted to make sure i have the correct flywheel. thanks
mh822
102
Dec 5, 2025 03:49 PM
01f350
Jan 4, 2010 06:51 PM
lasthighboy
Feb 24, 2008 02:47 AM
txen
May 8, 2007 01:39 AM
albatrosss
Jul 6, 2004 01:07 PM
