1952 restore questions
Old Nov 21, 2012 | 08:17 AM
celtic11's Avatar
celtic11
A new question has formed...I admit that I don't know a whole lot about converting from 6V to 12V but I am pretty sure that is what this box anchored to the firewall does. The wiring in my truck is totally shot and spliced and taped, etc. I am going to order a new wiring harness and just wondered if this conversion requires modifying things or will the wiring harness pretty much work as is?
Old Nov 21, 2012 | 08:02 PM
celtic11's Avatar
celtic11
Finding very little info...I am sure there has been a thread about this before that addresses my previous post.
Old Nov 21, 2012 | 08:28 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Can you show us a picture of this "box" you're referring to? Would be helpful...
Old Nov 21, 2012 | 09:23 PM
celtic11's Avatar
celtic11
My bad...I just looked closely at the box and I think it is an electric ignition box. Motorcraft on the side, maybe 4 inch by 4 inch. Sound right?
So now I am trying to find out if my truck has, in fact, been converted to 12 volt. My battery has two caps, I popped them off and there are six holes. Someone told me that that says it is a 12 volt. Anyone agree? I have an alternator but no markings on it or the compressor.
Old Nov 21, 2012 | 10:36 PM
dmack91's Avatar
dmack91
Each cell in a battery is 2 volts, so sounds like someone already converted it. Not to mention, I am pretty sure the the electronic ign. box didn't come in 6v .
Old Nov 23, 2012 | 03:18 PM
celtic11's Avatar
celtic11
So I am back to my original question:
If you just buy a new wiring harness for the truck, what will you encounter when compensating for the 12 v conversion?
Old Nov 23, 2012 | 04:53 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Since it has a 302, it's a pretty safe bet it has a 12 volt system, at least for the engine/starter/etc.
The switch from 6v+ to 12v- isn't a big deal. If you're going to buy a new harness, get a custom set-up like EZwiring, Painless, or another equivalent. Many of the speed shops like Speedway offer their own, and other variants. Typically, the entire wiring harness will cost less than all the parts of an original reproduction, and will be easier to install.
The modern harness will have a fuse block and connectors to make the job fairly easy, and very safe. The only problems you should run into will be if you choose to use the original gauges. Even then, there are ways to step down the voltage at the gauge, or the sending unit, to compensate.
Edit: In your case, the sending units on the modern engine will likely be 12v, so it would be easiest to step down the voltage at the gauge. The starter relay (sometimes called a solenoid) will have to be 12v, but again, it probably already is, since you have the modern engine. You will also have to change all the bulbs, of course. Otherwise they light up really bright for a few seconds, then burn out. It's pretty, but a waste of good 6v bulbs.
Personally, for the money, I like EZwiring, but that's just my opinion.
Old Nov 23, 2012 | 08:14 PM
celtic11's Avatar
celtic11
Thanks for the suggestions.
Old Nov 24, 2012 | 12:19 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The best I can tell from the codes I have seen on the net, my transmission is a C4 from a 1979 Fairlane. At this point, I dont know if it would roll in park or not because it will NOT go into park...reverse is as far as the shifter will go.
"UnderthebridgeJim" is our resident C-4 expert, check out this thread for a possible solution to your trans problem:
https://www.ford-trucks.com/forums/1...d-c4-help.html
Old Nov 24, 2012 | 09:53 AM
rhopper's Avatar
rhopper
Doc's right on the money. Fix it and drive it. Tackle all of the little problems while the truck is still driveable. Once you start the big frame off resto, you're off the road for years. My truck wasn't in running shape when I got it. It took six years of work before I got to drive it.
Old Nov 26, 2012 | 09:37 PM
celtic11's Avatar
celtic11
What is the trick to getting the steering column out of the gear box? There is a collar around the base that I have loosened and everything inside the cab is off.
Old Nov 26, 2012 | 10:55 PM
51PanelMan's Avatar
51PanelMan
Why do you want to remove the steering column from the steering box? It's recommended to remove the steering box and column as an assembly. Pull the steering wheel, jack up the truck and remove the assembly from underneath after you have unattached the steering box from the frame and pitman arm. You also need to remove the plates on the floor around the steering column. Removing the assembly through the cab is possible, but may take some wrangling.
Old Nov 27, 2012 | 09:11 AM
  #28
johnnydevil55's Avatar
johnnydevil55
rebelwire.com has really good deals on wire harnesses.
third_edition
1947 and Older Ford Trucks
21
Jun 6, 2016 01:31 PM
Gear Up
Mar 23, 2013 11:03 AM
ADTMan
Nov 29, 2011 08:37 PM
svt2205
May 21, 2007 10:33 AM
ellsdemon
Nov 27, 2006 06:31 PM
