Roaring noise...what is it???
Oct 29, 2012 | 01:19 PM
I have a 2000 X 5.4... There is a loud roaring noise when releasing gas pedal or stopped (doesn't matter whether its in park or drive)...noise stops when giving gas...the noise is almost like a bull horn...there are no engine lights on so can't get a code...
Oct 29, 2012 | 09:13 PM
Obstruction in the air plenum?
Oct 29, 2012 | 11:29 PM
Could just be the engine fan engaging. It sounds like an F18 w/ afterburners when the fan clutch engages. <!-- / message -->
Oct 30, 2012 | 12:41 AM
That's what I was thinking, they spin pretty good when they are cold and idling and some probably grab better that others.
Oct 30, 2012 | 02:30 AM
Probably not the fan as it will get louder with the gas.
I'd, too, suspect an airway obstruction or more than likely, an air/vacuum leak.
Check your intake assembly first. Pop the hood and listen for the noise and try to pinpoint its location.
Oct 30, 2012 | 08:29 AM
My 250 work truck does this sometimes. Everytime our mechanics checked it out it ended up being the IAC.
Oct 30, 2012 | 09:04 AM
Got one of these in the back seat?
Oct 30, 2012 | 09:40 AM
You'll shoot your eye out
Oct 30, 2012 | 10:44 AM
Stick a broom in the fan to eliminate that possibility. It is starting to sound more like an intake noise though.
Binkowski
Jan 29, 2018 04:47 PM
andrewsmith
Oct 6, 2007 07:37 AM
RangerPilot
1983 - 2012 Ranger & B-Series
Mar 22, 2007 06:41 PM
DueCat
Oct 26, 2006 06:41 AM
HotF150
1997 - 2003 F150
Sep 13, 2003 08:27 PM
