Fan noise/engine being loud
Old Aug 14, 2017 | 09:47 PM
Binkowski's Avatar
Binkowski
Hi all,
So I recently towed a small trailer from Indiana to New Mexico. Of course the a/c doesn't work yet so I had the windows down and in certain parts of the trip it made sense to turn the OD off so the transmission wouldn't keep down shifting. It wasn't a bad trip. Delivered a bunch of stuff to my brother in law that has been in storage while he was deployed overseas. 95 F150 Supercab, 5.0 auto
My issue now is that I have a lot of fan noise/the engine sounds like it's always just started and cold so there's that revving/vacuum cleaner like noise. I checked the radiator fan when cold and it will move by hand in the morning with a bit of resistance. The rpm's are all the same as before, the engine doesn't appear to be over revving, shifting is fine, temp gauge seems fine but it never really moves, oil pressure normal.
What could be causing this noise? What should I be checking? Any ideas?
Last edited by Binkowski; Aug 14, 2017 at 09:49 PM. Reason: Forgot vehicle details
Old Aug 15, 2017 | 12:36 AM
HeavyE85's Avatar
HeavyE85
Sounds like the fan clutch is stuck.
Old Aug 15, 2017 | 08:25 AM
Redark1's Avatar
Redark1
sounds like you came here in the hot weather and the fan clutch is working. sounds normal.
might be low on coolant too. the fan clutch takes a little while to uncouple when cold.
Old Nov 23, 2017 | 12:52 AM
HeavyE85's Avatar
HeavyE85
Remove the belts and start it. That will eliminate the belt or any accessories.
Old Nov 23, 2017 | 06:36 AM
Binkowski's Avatar
Binkowski
So it was a two part story. The noise was definitely the fan clutch. I have the 5.0 in my 1995 F150 SuperCab so it was a very simple job to replace. It was also very inexpensive to purchase the replacement too. The smartest thing I read was about putting a piece of cardboard over the radiator to protect it in case you bump it with things while working.
The second part was about a month later the water pump started leaking out the weep hole and was going bad. Ended up replacing it and the hoses as they were so caked with rust and deposits. I flushed and flushed with a hose until I got clean water and no more gunk coming out. Again, I thought it was an easy job because I didn't run in to any stuck bolts, the power steering pump and air compressor swing out of the way without removal, and I took my time flushing, cleaning and sealing everything up properly. It helped that I had another vehicle to use and a long weekend without work so I was not rushed to get the truck on the road in one day.
I did have one issue spring up....a leak in the tube that goes to the throttle body. I think the tube was all clogged up as it was never showing any sign of leaking until after I flushed all the gunk out. The new pump probably increased circulation too but anyway that tube has a pretty good bend in it and right at the bend it split open. I just used my dremel and cut off the bad section, leaving enough to put a longer hose on it. Looked like something that could be an issue in the future so I made sure to put a cap and small hose clamp in the glove box in case she ever starts to leak, I'll just cap it and be done with it. I live in Texas and Florida so it never gets cold enough to worry about ever needing it.
I did chicken out and not look at the timing chain while I was in there. Hoping that doesn't come back to bite me in the ***.
Old Nov 23, 2017 | 07:57 PM
Workingstiff's Avatar
Workingstiff
That very same throttle body heat riser went bad on me too about a month ago. I to flushed the whole system new t-stat etc.... The next day I came home and I was going to finish purging the system. I saw a spot of fluid under mid-motor. It was the fitting that screws into that riser block.It rotted out. The 1/4" hose makes a "U" bend.
Old Jan 29, 2018 | 04:47 PM
HeavyE85's Avatar
HeavyE85
Delete wearing post
ecotree
Jul 1, 2008 06:44 AM
ar29456
Jan 12, 2006 12:20 PM
agent614
Jun 12, 2005 09:44 PM
Marky Marc
Dec 2, 2004 09:28 PM
HotF150
1997 - 2003 F150
Sep 13, 2003 08:27 PM
