Whining noise
Old Oct 24, 2006 | 06:08 AM
DueCat's Avatar
DueCat
Whining noise
I have a 1997 Expedition E/B {5.4} 4x4 and I noticed a whining noise coming from the engine. Sounds like it's right around the fan blade or very close, when I turn off the engine it sounds like it's winding down to a stop, but I can't see any thing moving. Any ideas would be greatly appreciated. I know how to check fluids, that's about the extent of my knowledge.
Thanks
Old Oct 24, 2006 | 09:08 AM
89LX306's Avatar
89LX306
If it sounds like it is near the fan, you could spin the fan by hand (with the engine off) and see if you hear anything rubbing. A quick visual inspection of that area should make rubbing very obvious.
Does the "winding down" stop when the pulleys stop spinning? Could give you a direction to look.
Old Oct 24, 2006 | 09:24 AM
DueCat's Avatar
DueCat
The noise continues after I shut off the engine, under the cover that sayes Triton 5.4 L for a few min., then it stops. I checked the fan it's fine. As you can tell, I know very little about engines. It's the fan cluch going bad.
Old Oct 24, 2006 | 07:09 PM
FTE Herman's Avatar
FTE Herman
Welcom DueCat, you don't perhaps have a Load Leveling Suspension (LLS) do you? It could be the compressor your hear running.
Old Oct 24, 2006 | 07:18 PM
DueCat's Avatar
DueCat
I took it to the shop today and they said, what I was hearing was normal, but the fan clutch may be going out. What would be a good price to have that repaired? Any guesses?
Old Oct 24, 2006 | 07:19 PM
DueCat's Avatar
DueCat
How would I tell if I had a {LLS}?
Old Oct 25, 2006 | 10:16 PM
FTE Herman's Avatar
FTE Herman
^Air bags in the rear springs. A suspension switch in the passenger kick panel. A buzzing sound from time to time.
If they told you it was normal did they tell you what was making the noise? Perhaps the A/C system equalizing pressure? The fan doesn't spin for more than a second after you turn the motor off.
Old Oct 26, 2006 | 06:41 AM
DueCat's Avatar
DueCat
It was a valve making the noise.
