another problem from my rat rod
Old Oct 28, 2012 | 05:14 PM
HCSTROKER11's Avatar
HCSTROKER11
ok new problem is brand new battery..new connections..will only start on a jump start..can drive it up and down the road but once you stop and try to start it up again you get that clicking noise like the connection is bad..but it will start with a jump..idk somebody help me out
Old Oct 28, 2012 | 05:54 PM
jowilker's Avatar
jowilker
Wonder if the new battery is bad, or if you have a draw short that is killing the battery.
Go back to place of purchase and have it tested, in the vehicle preferably.
John
Old Oct 28, 2012 | 07:00 PM
rustywheel68's Avatar
rustywheel68
break out the voltmeter.
black lead on battery negative.
red lead on starter terminal.
hit the key.
how many volts have you got?
Old Oct 28, 2012 | 07:24 PM
HCSTROKER11
ok thanks..i have a battery load tester..ill try that first
Old Oct 29, 2012 | 09:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Make SURE the battery you buy has the teminals in the same location as the original. Some peeps don't pay attention, buy a GM or Mopar battery that have the terminals REVERSED.
Then when they install it, they hook the battery cables up bassackwards.
Old Oct 29, 2012 | 10:26 AM
MIKES 68 F100's Avatar
MIKES 68 F100
check your new cables too , if they are Autozone specials i've had them fail where they are connected
Old Oct 30, 2012 | 07:44 PM
HCSTROKER11
well i put the load tester on it and it showed the charging system was bad..so i charged the battery i was messing around under the hood and found the negative hookup on the brand new alternator had come unplugged..so yea i found the problem
Old Oct 31, 2012 | 04:26 AM
jowilker's Avatar
jowilker
Glad you found it.
John
BACKWOODS99
Aug 2, 2011 07:25 PM
mgomez
May 10, 2010 01:07 PM
cabloom300
Dec 17, 2009 04:05 PM
SS66
Feb 27, 2007 03:12 AM
terrylbu
Nov 6, 2002 05:34 AM
