Battery issues
Old May 9, 2010 | 05:54 PM
mgomez's Avatar
mgomez
Battery issues
I have a 84 f 150 and at first I thought it was a dead battery but whats happening is my truck will start but if i leave it off for long periods of time it wont start (acts like battery is drained) but its picky about that because for example when it started up perfectly when i was goin to work today started up fine when i was going to and from my break, started up fine when i was comin home, but on my way home i stopped at the gas station and when i went to start it back up after that it was dead! I had to get a jump. it was only sitting for 5 minutes maybe. I have installed a brand new battery and a brand new alternator. what could be my problem?
Old May 9, 2010 | 06:01 PM
83mike's Avatar
83mike
get a multimeter and check it. There may be a drain or a short you haven't seen.
I will say from experience that MY problem when the exact same thing was happening was an internal short in the battery that wound up melting a hole through one of the battery posts (on the battery itself) a new one cleared it right up.
However that's VERY uncommon. i would check the battery voltage when it's acting dead and see if it is truly dead. Then if it's not try jumping the starter solenoid and if it cranks over it MIGHT be the solenoid going bad.
Old May 9, 2010 | 06:54 PM
ctubutis's Avatar
ctubutis
When it happened to me, it was a failed starter solenoid. Did you hear the solenoid clicking
when you were trying to start it?
Old May 9, 2010 | 08:23 PM
mgomez's Avatar
mgomez
YES!!! Whenever I turn the keys i hear it click and then all the lights inside and out turn off!
Old May 9, 2010 | 09:23 PM
83mike's Avatar
83mike
check your battery voltage and terminals. take them off and clean them. check the ground to the block as well. that sounds like a ground or loose terminal problem.
Old May 9, 2010 | 10:09 PM
ctubutis's Avatar
ctubutis
I agree on the ground thing.
Old May 10, 2010 | 11:49 AM
mgomez's Avatar
mgomez
I have done that. I took both terminals off and sanded them down and the ground was on the chassis when i bought it not on the engine.
Old May 10, 2010 | 01:07 PM
Franklin2's Avatar
Franklin2
The large ground wire needs to be on the engine. The factory had a clamp that grounded the frame and the engine, but if you don't have the original cable, hook the cable you have to the engine, and then run another short one to the frame.
The priority current user from the battery is the starter, and it's bolted to the engine, so you need to run the large cable to the engine block. The engine is mounted in rubber mounts, so the frame ground won't do you much good as far as the starter is concerned.
