Stock system straight pipe.
Old Oct 28, 2012 | 09:22 AM
Steve8686's Avatar
Steve8686
Cant find specific answer through a search so here goes. Can a guy with no emissions in his state cut the exhaust right in front of the cat and turn the pipe down and call it good to help open things up. Also, where could a guy find a 3.5" pipe that turns down? Thanks for any help from anyone that has done this and if you have had any issues.
Old Oct 28, 2012 | 09:32 AM
BigAlsPSD's Avatar
BigAlsPSD
You need to check with your local laws, but in Arkansas, as with many states, turbos are considered mufflers, and you can run without additional noise reduction.
As for the pipe. I would hit up a local exhaust shop.
Old Oct 28, 2012 | 09:36 AM
pin8246's Avatar
pin8246
You prob can, but making the pipe that short I would think would make it annoying to drive. Mines straight piped, but I have it all the way to tip, and its still kind of loud.
Old Oct 28, 2012 | 10:03 AM
Cmedic's Avatar
Cmedic
Some states also require exhaust to exit past the passenger compartment so I would check with your local law enforcement.
Old Oct 28, 2012 | 11:00 AM
kell104's Avatar
kell104
Mine has nothing from the turbo to the tailpipe behind the rear tire. It is loud but not terribly so cruising down the road. Under my heavy right foot it does wake the neighbors. You should at least get the outlet behind the passenger compartment. just for safety's sake.
Old Oct 28, 2012 | 11:16 AM
Tugly's Avatar
Tugly
Soot: A member here did something similar and the whole undercarriage is buried in soot.
Noise: The sound exiting under the truck will resonate something fierce at specific RPMs, effectively turning the whole truck into a speaker cone... that's heard best in the cab.
Riffraff sells a muffler delete pipe, but you have to buy the band clamps separately.
Old Oct 28, 2012 | 12:40 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Don't do it like that. No good at all would come from it. Besides, that sounds like a dodge mod. just sayin.
Old Oct 28, 2012 | 01:29 PM
Steve8686's Avatar
Steve8686
Ok, sounds like no good. Thanks for the input.
Old Oct 28, 2012 | 08:37 PM
MTDewX's Avatar
MTDewX
I bought my old 00 truck with the muffler gone and replaced with that flexible exhaust pipe in its place. so it looked stock.
worked for me till I got a MBRP or what ever that brand is.
now I have a van and the exhaust is last on the list
Old Oct 28, 2012 | 08:46 PM
UP_There's Avatar
UP_There
get a muffler delete pipe, and keep your muffler for "just in case" if you sell the truck, or if they suddenly want to start requiring emissions testing in your area...
Old Oct 28, 2012 | 08:51 PM
yfz 450's Avatar
yfz 450
I just put an exhaust on my truck it's an 03 and to my suprise it didn't even have a cat. The truck was bought brand new by my grandfather and he never did a thing to it. Did some trucks come with out cats? I live in NY and a's of right now I don't have to pass emissions but they are trying to change it.
Redneckmorton
May 21, 2012 10:00 PM
48' fordster
Aug 6, 2009 12:11 PM
merlynr
Aerostar
Jul 3, 2006 05:34 PM
MemOrex
Exhaust Systems
Mar 29, 2006 04:48 PM
majorpecs
Apr 12, 2004 05:45 PM
