Exhaust Pipe TOO big??
Old Mar 28, 2006 | 12:39 PM
MemOrex's Avatar
MemOrex
Hey guys/gals, right now on my 93 F-150 w/302 I have a rigged up exhaust and need to fix it lol.
It has no cats, and I Y'd the 2.25" downpipes into a Single 3" pipe that runs thru a 3"In/Out Flowmaster. Right now, its dumped right under the cab, so needless to say its loud.
My question is, will it hurt any if I run the 3" pipe all the way back to behind the wheel, and maybe put a 4" Tip on it? (lol)
Old Mar 28, 2006 | 01:09 PM
weeds's Avatar
weeds
Might actually be better for the truck since it's not sitting in all those exhaust fumes from the cab back. I wouldn't go with a 4" tip though, that seems a little excessive. Maybe a 3-1/2" but I wouldn't go bigger than that.
Old Mar 28, 2006 | 04:42 PM
rusty70f100's Avatar
rusty70f100
Well if we look at it scientifically:
2.25" pipe
1.125 radius
12.5"^2 area at 2.25
25.0"^2 area wanted when pipes are joined from both sides. (12.5*2)
2.5" pipe:
15.4"^2
3" pipe:
22.2"^2
3.5" pipe:
30.2"^2
So 3" pipe would be the closest. If you run it back farther your lungs and your ears will thank you. I'd forget about the tip.
Old Mar 29, 2006 | 12:27 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Reduce above pipe area by 8% to 10% as pipe is measured in OD and exhaust gas is thru the pipe ID. Unless the motor fires cylinders simultaneously from both banks (not going to happen) the double pipe area dosen't apply, this was from Burns Stainless who build all out exhausts from headers to tips, Indy to Formula 1 motors, $2,000 headers up. I think they know exhausts.
On turn downs under the truck you have to be mad at yourself as any long trip you'll want to get away from the truck, do I hear noise fatigue?
.....=o&o>.....
Old Mar 29, 2006 | 04:48 PM
Beechkid's Avatar
Beechkid
You're fine.
the5schlueters
Mar 27, 2013 07:03 PM
genck08
1997 - 2003 F150
Feb 24, 2011 12:29 AM
BRay09
25
Jan 18, 2009 03:13 PM
powerstroked162
6.4L Power Stroke Diesel
75
Jul 28, 2007 12:23 PM
Finally
Feb 16, 2005 03:27 AM
