Injector replacement questions
Old Oct 25, 2012 | 01:13 PM
Langpie's Avatar
Langpie
Have read many posts, watched youtube videos so feel I can tacle this pretty easily. Have a few questions prior to doing it... Have seen/read people pulling the 2 1/8 allen bolts inside the head and letting it drain for 30 min prior to pulling injectors. Have also seen/read people pulling the rear injectors first. I do not have anything to vacuum the injectors so will be just forcing oil out the through the glow plugs. Do I need to do rear first? and should I crank over by hand prior to turning over by key? Also where exactly do I pry on the injector to remove? No clear video or pics I could find.
Old Oct 25, 2012 | 01:37 PM
SkySkiJason's Avatar
SkySkiJason
I never pull the allen head plugs... Do pull rear injectors first so most of the oil and fuel will go in those cylinders. I use a piece of 3/16" brake line tubing on Mighty Vac hose to slurp out cylinders, then install injectors, then turn engine over a couple revs by hand before installing GP's.
If not installing new UVCH's, be sure to do the $0.50 mod. Don't use aftermarket UVCH's or VC gaskets!!
Old Oct 25, 2012 | 01:59 PM
SkySkiJason
After you remove the injector hold down bolt, the collar will slide up and off the other bolt. Then you pry up on the collar. I like to use a medium length prybar (12"??).
Mighty Vac is only $30ish and a couple bucks for a piece of brake line tubing... I dont recommend usong starter to spin engine over, especially if cylinders are full of liquid. I usually spin by hand again after its all together - just for good measure!
F0rdF0rever
22
Sep 8, 2012 06:22 PM
bigbubba87
Aug 16, 2011 09:31 PM
Red Cobra
13
Nov 24, 2009 12:38 PM
MustangMatt96GT
34
Nov 14, 2009 10:43 PM
holiday187
Dec 7, 2007 09:51 AM
