Replacement cab
Old Oct 25, 2012 | 09:19 AM
nickelndime79's Avatar
nickelndime79
Replacement cab
I'm slowly building the truck I wanted back when I was 16 years old. I'm close to starting on getting the body work started. Up to this point I've done all the mechanical work myself but body work is going to be hired out. So yesterday I load up my cab and take it to my body man. I know the floor and cab corners are shot but I wanted to know how many nickel and dimes I'll have to come up with. Long story short he tells me to find a new cab that I'll be way money ahead. So now the hunt begins!!
Is there anything I need to look for specific or all the cabs made the same?
I'm replacing a '79 f250 manual non air cab. Although I got another parts truck with air but it's a extended cab so that's not an option. I may add air to this one with the parts off the extended cab.
Old Oct 25, 2012 | 10:17 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If you want to add A/C then look for a factory A/C cab, it'll save you having to cut the (big) hole in the firewall.
Is your truck 4WD? mid-77 and earlier F250 4WD cabs had narrower frames so the rear mount holes need to be redrilled.
Also, on earlier cabs, shoulder harnesses weren't standard equipment and chances are the cab won't have the mounting points for them, these aren't easy to add either.
Some cabs don't have the removeable trans tunnel cover, although these are easy to add, the cut lines are already marked.
Old Oct 25, 2012 | 10:39 AM
pboffroad's Avatar
pboffroad
Hey nickle and dime I have a single cab that came off of a 79 F 350 that cab is in good shape the floor pans however need replaced I can go take a picture if your interested oh and this cab also has the factory a/c unit under the dash Cab was 4C4 with automatic
Old Oct 25, 2012 | 12:41 PM
nickelndime79
Yes Mike it is a 4x4. So it sounds like I want to look for a 78-79 cab. I was wandering if the cab was different for the manual and auto trans or are all the cabs set up the same so you can bolt up the clutch and brake assembles.
Old Oct 25, 2012 | 12:44 PM
nickelndime79
PB I'll keep you in mind if you want to send some pictures
Old Oct 25, 2012 | 01:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The clutch and brake pedal assy will bolt up, an auto cab will have a rubber plug where the clutch rod goes through. Some auto and some 3 spd. manual 2WD cabs don't have the removeable trans tunnel. It's easy to cut ot the floor pan and add your trans tunnel cover.
Here are a couple of pictures of a solid floor without the removeable trans tunnel.
Kuboita
Nov 24, 2018 09:12 PM
ThatOneGuyWithThe79
Oct 21, 2011 08:02 PM
bwalt11
Jun 25, 2010 07:02 PM
SasquatchF-250
Aug 8, 2005 01:12 PM
classyfish
Paint & Bodywork
Jan 29, 2003 07:12 PM
