cab corner where are you?
Old Aug 7, 2005 | 09:15 PM
SasquatchF-250's Avatar
SasquatchF-250
i'm looking for a cab corner to place my rotting out one. i've tried NPD and LMC with no luck.
Are there any other places to look?
Old Aug 7, 2005 | 09:19 PM
79pos's Avatar
79pos
Jeff's broco graveyard has them for regular cabs through crewcabs.
Richard
Old Aug 7, 2005 | 09:40 PM
toddn78's Avatar
toddn78
Auto Krafters has them too.
Old Aug 8, 2005 | 01:53 AM
1978fordf250's Avatar
1978fordf250
I thaught LMC truck has cabcorners for both the streight cab and the extended cab trucks.
Old Aug 8, 2005 | 06:33 AM
skips69's Avatar
skips69
They are available through the aftermarket now as mentioned - even for the super and crew cabs. With all the bending, cutting and messaging that's required on them though (at least with my experiences), I've started using pieces from old beds recently (for free). There are lot's of rotten beds in the junkyards. Usually the beds around here have rotten wheel wells and rear sections, but the fronts are still good. I just cut along the front/lower portion of the beds (usually this is still solid metal) and the body lines match perfectly to the cab corners. Cut out a bigger section than needed, then trim and tweak as needed. Tack it and glass it from there.
Old Aug 8, 2005 | 10:29 AM
theonlybull's Avatar
theonlybull
napa, or any of those type stores should be able to get them..... although, the ones i got from napa, were far from fitting the truck....
Old Aug 8, 2005 | 11:05 AM
71LTD390's Avatar
71LTD390
I got my cab corners from LMC. They fit well. Just make sure and drill some drainage holes into the inner lower piece of metal behind the cab corners. There weren't any in mine and Ford had put sealer around the bottom of the cab corners also. They were chocked full of crud that had no place to go and no way to get to it. And coat the backsides well also. I prefer to glue in cab corners followed by rivets. It bothers me to weld a blind area. No way to completely paint the spots that the welding burns off. And get the tall cab corners. That keeps your joint up high away from any moisture down bottom.
Old Aug 8, 2005 | 01:12 PM
Mil1ion's Avatar
Mil1ion
Look on the left side of the page for FTE sponsor sites.
They have Ford Truck parts.
Blue Oval is a good place to start.
whalebus2112
Jun 7, 2014 08:19 PM
Diesel 724
Oct 5, 2013 11:14 PM
schoo
Jan 30, 2013 11:44 PM
4x41977
Nov 15, 2012 08:44 PM
q_ball
Mar 19, 2001 09:54 AM
