Any ideas while i have it pulled
Old Oct 23, 2012 | 06:27 PM
thompson2112's Avatar
thompson2112
my 89 7.3 is leakin from the heads and valve covers. I have it all pulled from the truck now to begin changin them out and was wondering if there was anything i should change for prevenetive maintenance glow plugs, injectors or anythings and whats the best brand to go with.
Also my previous radiator had oil in and from what i had heard its either from bad head gaskets or blow o rings in the oil cooler was wondering if there is anything else i could be from
Old Oct 23, 2012 | 06:29 PM
SnuffthePunkz's Avatar
SnuffthePunkz
If you have it out, just do it all if you have the money.
Full gp/injectors/return line kit here.
6.9L 7.3L IDI Diesel Tune Up Kit - Fuel Injectors, Glow Plugs, Installation Kit | eBay
Old Oct 23, 2012 | 08:30 PM
hairyboxnoogle's Avatar
hairyboxnoogle
If you ever plan to turbo, its an ideal time for head studs, and even if not, alot consider it to be good insurance.
Old Oct 23, 2012 | 10:13 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
glow plugs and relays isn't really anything ya need to replace......well.just make sure there are no off brand/non motorcraft plugs swelled up and stuck!
otherwise,those can all be done easy as pie in the truck anyway.its not like we're limited on space and emissions crap in our way like on PSD's.
if i had my engine out,mine wouldn't go back in without the torque cam.
(search-advance search-username enter: fordf250hdxlt-check threads started by-in keyword enter: torque cam)
Old Oct 23, 2012 | 10:22 PM
Gavin Dhillon's Avatar
Gavin Dhillon
id definitely reseal the oil cooler if i was you
Old Oct 28, 2012 | 08:46 PM
thompson2112
Well i have it out still only have the time to do work on it every now and again but this next week i have a good four days to work on it. it does have a turbo and i checked the prices on headbolts and summit said they have an arp kit for 550 which im not to sure i want to spend that since studs are more from what i have heard? Definetly going to reseal the oil cooler. Is there anything tricky to doing that and the head gaskets? if so tips would be appreciated little stressed about all this since its my first diesel but i am really quick to learn and have pretty good knowledge for being new to workin on one. Will definetly get some pictures up once its done everyone on here has been a huge help to me.
Old Oct 28, 2012 | 08:47 PM
thompson2112
as for the cam would that show any significant difference? and how hard of a job is it
thanks
Old Oct 28, 2012 | 09:10 PM
RacinNdrummin's Avatar
RacinNdrummin
You can get studs a lot cheaper than from summit if you have a 7.3, just do some reading.
Cams are a good upgrade for drivablility, and if you are already going to have the engine half torn down, might as well add one of those too, its not too big of a job. There are a few to choose from nowdays...
Old Oct 28, 2012 | 09:33 PM
thompson2112
alright ill definetly look into it and see what i can find
Old Oct 29, 2012 | 01:39 AM
thompson2112
Anyone happen to know the seal size for the oil cooler? Got a standard and metric kit not sure if the size is in there or not havent gotten to pulling it off yet
Old Oct 29, 2012 | 04:44 PM
kobaltblue's Avatar
kobaltblue
Advanced auto has a lower end oil seal kit comes with oil pan gaskets front seal rear seal cooler seals and timing and water pump, The oil cooler is a PITA to do if you have some BIG wood clamps or some kinda big clamps to press it back together other wise youll have to take it to a shop and have them press it back together for ya.
And you need a puller to get the spacer ring off the back seal.
Old Nov 6, 2012 | 07:21 PM
thompson2112
Got the whole thing torn apart finally and just finishing up on cleaning it before i put it all back together had a question though bought some new glowplugs motorcraft zd9's and they have different tips than the old ones where can i pick up the new electrical needed?
Mowing Man
Sep 19, 2013 07:52 PM
05 f250 6 inch lift
Aug 14, 2011 06:02 PM
xlmine
Nov 10, 2010 09:25 AM
rmalottwtes30
Aug 17, 2008 04:06 PM
Rocketattack
Missouri Chapter
Oct 27, 2006 05:32 PM
