what gaskets do i need
Old Aug 14, 2011 | 02:04 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Im pullin heads off to install ARP studs. I know i will need head,intake an valve cover gaskets. what other , if any , gaskets will i need. Also, will i need to remove injectors an glow plugs if my head need to b surfaced ?
Old Aug 14, 2011 | 08:07 AM
cheezit's Avatar
cheezit
you also need rocker box gaskets. its also a good time to replace the oil cooler. injectors and glowplugs should be removed porior to removing the heads to provent damage to the tips.
you will also need 8 injector o-ring kits.
Old Aug 14, 2011 | 12:08 PM
05 f250 6 inch lift
thanks cheezit. I am replacing oil cooler to an doing stc fitting,stand pipes,dummy plugs an new IPR valve to.i pulled it last nite an it had a tear in the screen.I tried the 12 volt test to see if it would click an it didnt.Do i need any special tools to remove injectors an glow plugs ???
cheezit's Avatar
cheezit
nope none at all
Old Aug 14, 2011 | 01:09 PM
m-chan68's Avatar
m-chan68
Yes, you do. It's called a thin-walled chrome 12-point 3/4" or 19mm socket to push the injector connectors through the rocker arm carrier without damaging them, before you get your long shank TX-40 socket to remove the injector hold-downs. A deep 10mm socket is all you need to remove the glow plugs. You may want to replace your glow plug harnesses as well if you damage them during removal. For me, I've had very poor luck with attempting to remove them without damage on the last few that I've been under the hoods of.
Old Aug 14, 2011 | 01:29 PM
2006powerstroke90's Avatar
2006powerstroke90
Intake and valve cover gaskets are re useable if not damaged.
If I were you I would do exhaust manifold gaskets.
I wish I did.
Old Aug 14, 2011 | 01:36 PM
2006powerstroke90
Also I would most definitely remove the injectors. At 250$ a pop it would suck to damage the tips would get expensive quick.
Also, when you go to reinstall the injectors take a q-tip and get all the oil out of the hold down bolt holes so they get torqued properly. And crank the motor over by hand before Starting it to ensure no bent push rods.
Old Aug 14, 2011 | 06:01 PM
05 f250 6 inch lift
Thanks for all y'alls info. It's worth more than I can say on here. This is the first diesel I have owned or worked on. So I want to do it right the first time.
Old Aug 14, 2011 | 06:02 PM
05 f250 6 inch lift
Also goin to reroute my ccv when I put it all back together.
Jeepincj7
Nov 11, 2012 10:15 PM
kornfanjoe
Jul 26, 2012 04:32 AM
JT250
Mar 26, 2011 11:26 PM
chris64
19
May 21, 2010 10:42 AM
YoungFordAddict66
32
Mar 10, 2010 06:21 AM
