FE valve covers
Old Oct 22, 2012 | 02:11 PM
abyars111's Avatar
abyars111
FE valve covers
I need a set of the painted steel FE valve covers for my 390. Someone overtightened them in the past and damaged them. The local yards here don't have any. Does anyone have a good spare set they'd part with?
Old Oct 22, 2012 | 03:08 PM
Freightrain's Avatar
Freightrain
Using a small hammer and a strip of metal/wood you can straighten out the rail enough to make them seal again. Very typical and done many times.
Take a strip of metal(better then wood) and clamp it in a vise with enough sticking up to allow valve cover to reach it. Put the valve cover down upside down(looking at inside) so the metal is supporting the rail(where it's bent). Then using a small hammer, pound the raised portion of the rail back down flat against the strip. Work slowly and evenly.
Old Oct 22, 2012 | 04:08 PM
HIO Silver's Avatar
HIO Silver
Painted steel? How about some eye candy under the hood?
390-427-428 Valve Covers
Old Oct 22, 2012 | 04:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
People tend to overtighten the valve cover bolts, which causes the area around the bolt holes to flare outwards.
Take the covers off, lay on a flat surface, they'll be resting on 5 pedestals instead of laying flat. Finding used valve covers without the "pedestals" will be very difficult in this day and age.
Be aware that the FE valve covers used on 1958/64 Passenger Cars are different. Are rounded without any holes in them for oil cap/smog valve. These engines have an oil fill tube, right (passenger) side-front
Old Oct 22, 2012 | 04:28 PM
jowilker's Avatar
jowilker
With noted exception from Mr. Wilson. 352 & 360 VCs are the same, you don't have to go looking 390 to get a pair.
Also as noted reverse pounding will reverse the indention. I have had good success using wood to straighten. I would use wood over metal because of deep scratches that can be caused by metal.
John
Old Oct 22, 2012 | 04:39 PM
NumberDummy
1965/67 352 / 1965/68 427 / 1965/76 390 / 1966/67 410 / 1966/70 428 / 1967/78 330/361/391 FT engines / 1968/76 360 all use the same valve covers, gaskets.
I had an original pair of Cobra LeMans valve covers on my 1965 F100 and an original Cobra air cleaner. I hate to think what these would be worth today.
Repro's of both (made in Taiwan) were first offered in the 1970's. Were reproduced by a local (North Hollywood) Ford parts obsolete store. The owner was a Shelby "nut."
Store is still there today, but under a different name/owner: Mustang Service Center, Bovon Chungjotakapisit, who is known as Bo Chung...for an obvious reason.
Old Oct 22, 2012 | 06:17 PM
abyars111's Avatar
abyars111
just found a little yard close to my house that I didn't know about, the owner likes FEs, he has a barn full of parts, he has several valve covers, I found the exact ones I needed. thanks for the info numberdummy
Old Oct 22, 2012 | 06:41 PM
abyars111's Avatar
abyars111
numberdummy, the yard i visited today had a 391 from a big truck, he said the valve covers are taller than a 360/390, is that so
Old Oct 22, 2012 | 06:59 PM
NumberDummy
Parts catalogs say C7AZ-6582-A .. Valve Cover - 1965/76 FE engines & 1967/78 FT engines.
1964/66 FT engines use a different valve cover.
Old Oct 22, 2012 | 07:39 PM
abyars111's Avatar
abyars111
does that mean the 391 is a FT engine and it was only made 64-66? I'm still learning.
Old Oct 23, 2012 | 01:54 AM
NumberDummy
391 and other FT engines were made 1964/78, but valve covers specific to 1964/66, 1967/78.
FT engines installed in 500 series and larger trucks with one exception.
1973/78 F350's made exclusively for U-Haul came with 330 2V Medium aka Xtra Duty engines.
Scand
Sep 22, 2010 08:52 PM
OrangeJuice
Jan 17, 2010 05:59 PM
ford66
Aug 9, 2009 08:54 PM
stegmst
Jul 19, 2005 12:03 AM
Hillbillydeluxe
Feb 21, 2005 06:30 PM
