Valve cover hold-down tabs
Old May 21, 2008 | 11:57 PM
OrangeJuice's Avatar
OrangeJuice
Unhappy Valve cover hold-down tabs
Hi everyone,
My question is about the valve cover hold-down tabs for my 390 engine. I'm looking to buy some long tabs, but can only find the small triangle shaped tabs. Need something to help hold the corners down tighter. All the long ones I've seen are for Chebby's. Anyone know where I can get some long tabs to fit Ford valve covers?
Thank You
Old May 22, 2008 | 11:04 AM
bluesky636's Avatar
bluesky636
Why do you need them? They were not used on stock engines, just a flat washer with a bolt. Are you having problems with leaks? What gaskets are you using? Are you using rtv in the corners where the heads meet the intake manifold to seal that slight gap? Are the bolt holes in the valve covers distorted? They can be hammered flat carefully.
Old May 22, 2008 | 10:57 PM
Bear 45/70's Avatar
Bear 45/70
You should always make sure the valve covers aren't bent at the bolt hole. This needs to be check everytime the covers are off and never over torque the bolts, it just bends the covers again, causing the leaks or making a leak worse.
Old May 23, 2008 | 07:21 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I agree thats the #1 problem is useing warped covers...and not checking for straightness.... and as Bear mentioned Dimpled bolt holes... and after being in the trade for well over 30 years ... I still see professional wrench's to this day over tightening Valve covers.... JMO...
RJ
Old May 23, 2008 | 10:45 AM
dbossman's Avatar
dbossman
tabs
Originally Posted by OrangeJuice
Hi everyone,
Thank You
I think you need the Pontiac tabs. If i recall, they have a different hole size than the chebby's.
Tim
Old May 23, 2008 | 10:11 PM
jwtimme's Avatar
jwtimme
I used the universal ones from the local parts store they fit my chrome valve covers witch were crap. I bought some cast covers and have not had a leak since.
Old May 23, 2008 | 10:36 PM
Bear 45/70's Avatar
Bear 45/70
It is very hard to warp cast valve covers like you can stamped steel one.
Old May 28, 2008 | 09:42 AM
werneil's Avatar
werneil
hi, check the condition of your rocker cover's, maybe the flanges are distorted and require repairing, large spreader washers are not usualy needed
Old Jan 17, 2010 | 05:08 PM
Doozer75's Avatar
Doozer75
I believe the two bolts on the bottom I used small block Chev hold downs and the top middle hold down was for a Mopar 318.
--Doozer
Old Jan 17, 2010 | 05:59 PM
OrangeJuice
Welcome to FTE Doozer75. The valve covers I was using since this post have been replaced and upgraded to the cast aluminum Cobra Lemans style that have a much thicker flange on them. No problems with these newer ones.
OJ
netminderone
2004 - 2008 F150
Nov 5, 2019 09:40 PM
FullMetalDiesel
6.7L Power Stroke Diesel
Feb 4, 2017 09:41 PM
Sevrock
Jul 13, 2016 10:39 PM
DGMFORD
Jul 25, 2011 10:38 PM
faroffthetrack
Apr 23, 2004 11:21 PM
