Valve Cover 352 Engine
Old Aug 9, 2009 | 02:20 PM
ford66's Avatar
ford66
Which is a better valve cover as not to leak, aluminum or steel, on a 352 engine?
Thanks
ford66
Old Aug 9, 2009 | 06:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There reason FE valve covers leak is ppl overtighten them. That causes the area around the bolt holes to flare outwards.
Remove the valve covers, lay them on a flat surface, you will see the covers resting on 5 little pedestals.
With a body hammer and wood, you can repair flares in the covers, but it's time consuming.
Both new steel or aluminum valve covers will not leak...that is...until they are over tightened.
Old Aug 9, 2009 | 08:27 PM
ford66's Avatar
ford66
So Hummer, How tight is tight?
ford66
ford66's Avatar
ford66
Should I use anything on the valve cover gasket?, and is there a better gasket than cork?
ford66
Old Aug 9, 2009 | 08:33 PM
Bill W's Avatar
Bill W
Just snug, 10 lbs is about right
Old Aug 9, 2009 | 08:54 PM
Customcab's Avatar
Customcab
I've always been told cork on FE motors work better than rubber; but I like / use rubber type and as mention the leaks are cause by us tighten them to tight.
Mitch
Björn
Mar 1, 2016 05:58 PM
Zazoos
Oct 12, 2015 09:57 AM
hombre292
Nov 15, 2013 10:32 PM
OldHarley
Jan 8, 2010 01:48 PM
dan66tampa
Feb 11, 2005 12:16 AM
