Trbl code of P1378
Old Oct 18, 2012 | 09:32 PM
Stu206's Avatar
Stu206
Trbl code of P1378
Have seen code of P 1378 in Insight gauge, not CEL yet, but was in July this year, Mechanic says pending trouble code not to worry about till CEL comes on. Had FICM replaced three years ago and top half replaced in July 2012. Where should I go from here.?
Old Oct 18, 2012 | 09:35 PM
bismic's Avatar
bismic
Low FICM logic power. System detects less than 7 volts. Could be low batteries, loose connections (or excessive circuit resistance), bad relay.
Old Oct 18, 2012 | 10:06 PM
BLADE35's Avatar
BLADE35
I dont think I would put off Fixing it either your truck seams to be having alot of FICM Problems
your Relay is Labeled diffrent than what I am Posting Below but works the same Pull it out and note the 2 skinney terminals thats the control Circuit the Fat ones are the Power circuit
If you have a DVM you can rig up some test leads and test it use the car battery on the control circuit test with a DVM on the Power circuit
-a standard bosch-style relay will have 4 or 5 numbered leads (30, 85, 86, 87, and sometimes 87a). why they picked those numbers, I have no clue; but I can tell what they hook up to.
-30 = constant [positive (+)] power (usually wired directly to car battery)
-85 = coil ground (wired to the negative (-) battery terminal or any grounded metal panel in the car)
-86 = coil power (wired to the control source. could be a switch, or it could be the car's IGN or ACC circuit.)
-87 = switched [positive (+)] power output. (when the relay coil is powered, lead/pin 87 is connected to lead/pin 30)
-87a = [on 5 lead/pin relays only] this lead/pin is connected to lead/pin 30 when the coil is NOT powered.
here is the bottom view of a standard 4-lead Bosch-style automotive SPST relay
here is what happens inside the 4-lead/pin SPST relay. on the left, the coil is NOT powered. on the right, the coil IS powered. notice the switch changes positions when the coil is powered. when the coil is powered, pins 30 and 87 are connected. when the coil is NOT powered, then pin 30 is not connected to anything, therefore it is in the 'off' position.
Click this bar to view the full image.
Old Oct 19, 2012 | 12:44 PM
Stu206's Avatar
Stu206
On the Relay, where's its location and also approx cost of new one, as truck was at the dealers on Wed this week and Mech there said wait until CEL is on, won't trust report in Edge Gauge, but this is second time that the code has shown up in a month. Both batteries were replaced in Sept 2011, cause mech then had said low input to FICM if I remember right, different dealer then. I would like to get this issue fixed as I have an aftermarket plan on truck for repairs that is over at end of this month.
Old Oct 20, 2012 | 03:39 AM
egregg57's Avatar
egregg57
I have had this intermittent code as well. Running Edge Juice with Attitude. I have been looking into this the last couple of years. It is my belief that this is a bug with the Edge.
I get the Ficm Control Circuit Voltage: Low code intermittently. I dropped $230 on batteries and a couple of other items two and a half days ago. Cleared codes upon start up after the batteries were replaced. No FICM Code. Ran for an hour, No Code.
Yesterday, after starting, before leaving the driveway the code popped again.
I have checked voltage to and from my FICM and I have reflowed the FET's and cleaned up the connectors. I am confident my FICM is performing well and the voltage being supplied to it is good.
The only thing I have not checked is the Altenator to see what voltage it is supplying under load. But I don't believe that the altenator is going to have any effect unless it fails to no output. Additionally I don't think the altenator comes into play until the glow plugs shut off. But not real sure of that.
Just out of curiousity, are you seeing a P0528 "Electric Fan Clutch: No Signal"? This is another one of those ghosts...
Eric
Old Oct 20, 2012 | 08:08 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Relay location FICM 18 and 304
Old Oct 20, 2012 | 09:32 AM
bismic's Avatar
bismic
Rusty - in your drawing don't you have the locations of Relays 303 and 304 switched?
Old Oct 20, 2012 | 01:57 PM
Rusty Axlerod
YES, Dang! Thanks Mark. I uploaded the picture to my album here at FTE, if I correct the pic and upload again with the same name do you know if it will be corrected in the posts?
ON EDIT:
It is fixed in this post. Uploading another version didn't replace the old one. The new pic got assigned a new picture ID# so no auto fix. Deleting the incorrect pic removed it from the other posts, sorry for any confusion
Old Oct 20, 2012 | 03:39 PM
bismic's Avatar
bismic
Thanks for the pic Rusty!
Old Oct 20, 2012 | 05:54 PM
BLADE35's Avatar
BLADE35
Reps Given Great Job
The Rest of you guys that come acrossed this should send Rusty some reps
It takes some effort and time to do this stuff Plus Getting it Loaded on to FTE takes time
Thanks Rusty
Old Feb 4, 2013 | 10:09 AM
laboyma's Avatar
laboyma
06 F250 - I have trouble codes P1378 and P2291. I have read some of the threads.....I am still a little lost. Have own a diesel for about a year.....trying to learn a few things and break a couple of others.....If someone can give me a clearer answer as to what to do....I am game.....Thanks
Mike
hakukamana
Mar 10, 2013 05:09 PM
KrenzyRyan
Jul 3, 2011 11:48 PM
EaTmYtAiLpIpEs
Jun 6, 2007 11:08 AM
94F150Shorty
1978 - 1996 Big Bronco
Oct 27, 2004 04:54 PM
dr_db
Electrical Systems/Wiring
Apr 16, 2003 06:51 PM
