Sponsored by: Real Truck
testing relays
Old Jun 6, 2007 | 06:14 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
testing relays
can someone tell me how I can test a relay? THANKS!
Old Jun 6, 2007 | 08:24 AM
redford's Avatar
redford
FTE Leadership Emeritus
Try this:
http://www.autoshop101.com/trainmodules/relays/101.html
Old Jun 6, 2007 | 08:39 AM
edjunior's Avatar
edjunior
You ask it a question and wait to see if it answers your question correctly! Okay, sorry...just another Monday!!
Old Jun 6, 2007 | 11:08 AM
DAVE67FD's Avatar
DAVE67FD
Testing a relay is pretty simple.
I am guessing it is of the standard automotive "cube" relay. First, most relays have a diagram on its housing. Most of these you may need a magnifier to read. There are generally 2 terminals isolated from the other terminals. These 2 terminals are for the coil (12V) Typically these are not polarity sensitive but some have an internal diode (or LED for status) that is used for noise immunity and/or nusance tripping. The diagram on the relay should denote a diode or not. If not then the +/- wires can go on either terminal. Once the 12V is connected you should hear or feel the coil activate. Remove the 12V power. You will nead a ohm meter or continuity tester (you can make one from a simple battery and light if need be). If the diagram exists on the case it would be helpfull for you to redraw the diagram on paper if possible. Many relays will have a 3 pole configuration, meaning 3 sets of contacts for each pole so 9 terminals total (not including the 2 for the coil). A common terminal, a normally open contact (N.O.) and a normally closed contact (N.C.). Many relays are manufactured with their case the same but may eliminate some of the poles. Your relay may only be a single pole (3 contacts) or a double pole (6 contacts etc..). They can also have only 2 terminals per group meaning it is a single pole single throw (spst)
Typically the common terminal is the center terminal within its group. The remaining contacts will give you continuity either N.C or N.O.. The state of each contact will reverse when you put power to the coil. I know it all may seem a little confusing but after you get familiar with them their pretty easy to understand. Good luck
Dave
