Hey, numberdummy, can you decode an axle code?
Old Oct 16, 2012 | 09:01 PM
ol'chebby's Avatar
ol'chebby
1977 f150. 460/C6. 2wd. Rear axle is 2.75 open, 9in. the tag reads:WDM-BR 6KC
2.75 9 3854
What spline axles should this have? I need to convert to limited slip. Looking at unit from speedway, or should I swap a pumkin from another truck?
Thanks.
Old Oct 16, 2012 | 09:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
WDM-BR uses parts list #88. That list says axle is P/N D6TZ-4234-A. Axle spec sheet says that axle is 31 spline.
Old Oct 16, 2012 | 09:31 PM
HIO Silver's Avatar
HIO Silver
Swapping pumpkins is easy and relatively inexpensive. However, finding a 2.75 with limited slip might be a bit challenging. IIRC, more common with 3.25 and numerically higher gear.
You'll want to find a pumpkin with an "L" between the numbers denoting it has limited slip.. for example, a 3.50 pumpkin's tag would read "3 L 50". Again, always verify the gear and the fact that it does have an LS before ya plunk down your cash.
Old Oct 16, 2012 | 09:32 PM
ol'chebby's Avatar
ol'chebby
Cool, thanks. Would I be better to go aftermarket or oem for the limited slip? Any suggestions/ reccommendations?
I am familiar with the tag readings.."L" codes and gearing. I run a tbird IRS in my 51 Chevy. Just haven't really dealt with a 9. If I find a LS, could I swap my 2.73 gear onto it?
Old Oct 16, 2012 | 09:37 PM
ol'chebby's Avatar
ol'chebby
I am building this truck to live a life of liesure as a retirement hot rod to cruise around the Villages, Fla....a huge retirement center. He is replacing one he had way back when. It will be a cruiser, but may pull a boat from time to time. Having a 460, I don't want to gear it too low to keep drivability and economy (HA!). Would a 3.25 make a big jump? How does Ford adjust speedo gearing?
Old Oct 16, 2012 | 09:44 PM
HIO Silver's Avatar
HIO Silver
Ford adjusts the speedo by matching the driven gear at the end of the speedo cable at the tranny.
A 3.25 gear is decent for getting off the line with a boat and a highway gear too... it's an acceptable compromise. Being ginger off the line with a 2.75 is doable too.
Old Oct 16, 2012 | 10:59 PM
ol'chebby's Avatar
ol'chebby
Researching a Summit Trac loc and a powertrax no slip. Any opinions on either? The powertrax says no setup, 1 hr install. Would the trac loc from Summit have to set the lash, etc.?
Old Oct 22, 2012 | 09:57 AM
ol'chebby's Avatar
ol'chebby
Anyone? Which would be the quickest, easiest, most effective?
Old Oct 23, 2012 | 04:45 AM
garthneddy's Avatar
garthneddy
You will need to set up the ring and pinion if replacing the current open carrier with a limited slip carrier. The Powertrax installs into the open carrier, replacing the spider gears so there is no need to mess with the gear set. This will be much cheaper, easier and faster.
joegeds
Oct 5, 2014 09:23 AM
pditmars
Jan 19, 2005 11:42 AM
rolinron
May 16, 2004 11:21 AM
Red97
Oct 6, 2003 07:03 AM
cw50must
Mar 23, 2002 03:08 PM
