Adjustable pedal fix!
Old Mar 12, 2014 | 08:56 AM
  #151
jimbo020's Avatar
jimbo020
well crap.... Thats too bad.
As far as I can tell, the gear is working properly on mine, but the square ends of the little cable have been rounded off.
Old Mar 26, 2014 | 08:59 PM
  #152
Sdsommers's Avatar
Sdsommers
I need your gear to repair my 04 Navigator.
Let me know what you need for an order.
Old Mar 26, 2014 | 09:09 PM
  #153
Sdsommers's Avatar
Sdsommers
Old Mar 27, 2014 | 07:58 AM
  #154
Curless's Avatar
Curless
You can call me at 616-988-1315 or private message me. I am going on vacation this friday for 10 days. If you want one get ahold of me today. They are $85 to your door. mer@curlessautorepair.com is my paypal, don't forget to include your screen name, actual name and address and what year make and model you have.
Old Apr 30, 2014 | 01:20 PM
  #155
Curless's Avatar
Curless
The latest run of these is coming in on Friday the 2nd, let me know if any of you need one!
Old Apr 30, 2014 | 03:41 PM
  #156
kevinlu310's Avatar
kevinlu310
Sir, so will this replacement gear fit 2006 expedition xlt? Thanks a lot!
Old Apr 30, 2014 | 04:04 PM
  #157
Curless's Avatar
Curless
Yes it will sir!
Old Apr 30, 2014 | 10:51 PM
  #158
kevinlu310's Avatar
kevinlu310
Nice. Will check the gear in my truck tomorrow to make sure it's the culprit that causes the issue. Will order the replacement from you after it gets confirmed.
Yes it will sir!
Old May 2, 2014 | 12:06 AM
  #159
kevinlu310's Avatar
kevinlu310
Just tried to check the gear this evening based on instructions you posted earlier (https://www.facebook.com/media/set/?...2187651&type=3) Looks you already removed the plastic panel/cover under steering wheel before you get easy access to the pedals assembly. May I ask how did you remove the plastic thing? I was trying to take out the gear without removing it, but just a little too difficult. Thank you very much for your help!
Old May 2, 2014 | 08:36 AM
  #160
Curless's Avatar
Curless
If you are talking about the cover over the bottom side of the steering column, no I did not remove it. There is a black vanity cover on some cars and trucks under the edge of the dash that covers up the underside of the dash and wires, its held on by 3 or four push pins....that is all I would remove.
Old May 2, 2014 | 09:33 AM
  #161
kevinlu310's Avatar
kevinlu310
Thank you so much for your response, sir! Just carefully checked the instructions you posted again. So the only things I need remove are the three torx headed screws that hold the black plastic cover, nothing else, right? Is there something else, like some wiring and etc., that I need unplug?
One more question, on my truck, both the brake pedal and the gas pedal are supposed to be adjustable. Now both of them barely move. I noticed on the gas pedal looks there is also a similar gear cover. I guess there is another gear inside as well. So do I need order two gears, or just a single gear for the brake pedal will fix both of them? Thank you very much!
BTW: do you have some gears available at this time?
Old May 2, 2014 | 05:25 PM
  #162
Curless's Avatar
Curless
Yes, just the one cover off of the brake pedal. This is the spot that has the plastic gear that failed. The gas pedal will not be broken, thats where the motor is for both pedals. Yes, I have them in stock as of an hour ago!
Old May 5, 2014 | 08:52 AM
  #163
kevinlu310's Avatar
kevinlu310
Thanks, Curless! Will contact you to make an order of a gear.
Old May 5, 2014 | 12:30 PM
  #164
Curless's Avatar
Curless
No problem, just let me know!
Old May 17, 2014 | 02:13 PM
  #165
steps_man's Avatar
steps_man
05 navigator how do I order the part
I have the problem in an 05 Navigator, how do I order the part?
Thanks
