looks like a vacuum pump
Old Oct 15, 2012 | 08:32 AM
CR3999's Avatar
CR3999
There is this apparatus that looks like a vacuum pump on the passenger side fender well that has a bunch of vacuum hoses running to it . It runs as soon as I turn on the truck. It didn't do this before. Do I have to replace the pump or is there some kind of fix?
May as well do other things to fix the truck since I'm waiting to get my FICM back from ficmrepair .com. Can hardly wait to get it back to see how much better the truck will run.
Old Oct 15, 2012 | 08:45 AM
69cj's Avatar
69cj
The vacum pump should run as soon as the ignition is turned on. It should also cycle unless you have a vacum leak somewhere.
Old Oct 15, 2012 | 09:18 AM
CR3999's Avatar
CR3999
It seems to run all the time making a kind of a loud hum. It is a two wheel drive truck. Now that I think about it, it has been doing it since I had the grill replaced at the body shop and fixed the A/C. I hit a big dog and it toke out the condenser and trans cooler.
Old Oct 15, 2012 | 11:44 AM
BLADE35's Avatar
BLADE35
Is your heater stuck on Defrost????
Old Oct 15, 2012 | 12:56 PM
CR3999's Avatar
CR3999
Only when I first start it up, I can turn the control **** off and back on and it performs like normal. After the truck runs for a few moments.
Old Oct 15, 2012 | 03:39 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Remove the line form the tank and plug it.
Does it turn off now? If not the control is
bad and I don't know if you can just replace that
of it is the pump. If it stops then time to look for the leak.
Sean :=-drink
Old Oct 15, 2012 | 06:35 PM
CR3999's Avatar
CR3999
Thanks good idea. When I get evertything back togather I will do that.
2000F250guy
15
Feb 5, 2014 03:37 PM
jspence105
Dec 4, 2013 06:44 AM
4x4x
Jan 23, 2013 06:07 PM
Roasted7
Oct 21, 2012 06:04 PM
cak301
May 8, 2010 03:13 PM
