Vacuum Leak
Old Oct 14, 2012 | 10:37 PM
Roasted7's Avatar
Roasted7
Vacuum Leak
My heater only blows out of the defrost so I think I may have a vacuum leak. I can't see anything immediately obvious.
Does anyone know where I might find a vacuum diagram?
Thanks.
Old Oct 14, 2012 | 10:42 PM
BLADE35's Avatar
BLADE35
Does the Vac pump run??
Old Oct 14, 2012 | 10:43 PM
m-chan68's Avatar
m-chan68
Does your vacuum pump work? If not, check for power and ground to the vacuum pump connector with the key in the RUN position. If you are getting power and ground at the connector but the pump is not running, replace the pump and recheck.
Old Oct 15, 2012 | 07:46 AM
Roasted7's Avatar
Roasted7
The pump is definitely running. I just had all new injectors installed so something must have happened when they put everything back together. Doesn't seem like they would have had to mess with any vacuum lines.
Old Oct 15, 2012 | 08:42 AM
69cj's Avatar
69cj
Heater diverter valve in the water hose passenger side. Check that the grey vacum line is hooked up.
Old Oct 21, 2012 | 06:04 PM
Roasted7's Avatar
Roasted7
I found that if I pull the vac line off the control valve for the auto hubs and plug that line then the pump will build vacuum and hold it very well.
That control valve must be bad.
forkhorn
May 20, 2014 07:29 PM
2000F250guy
15
Feb 5, 2014 03:37 PM
Bobcat7
Jul 18, 2010 07:22 AM
mh34444
May 29, 2010 06:40 AM
cak301
May 8, 2010 03:13 PM
