Sponsored by: Real Truck
Multi-Function Switch !
Old Oct 14, 2012 | 03:22 PM
DetailerDave's Avatar
DetailerDave
After a year or 2 of having issues with the windshield wipers, turn signals, and brake lights, I finally decided to replace the multifunction switch. The brake lights occasionally didn't work, or the blinker didn't work, or windshield wipers wouldn't turn off, I figured the multifunction switch was the culprit. It was, and $154 later everything works correctly. While I had it apart, I was going to replace the rubber boot at the bottom of the column shift lever, at the column, but I almost choked when the parts guy said $66 for that little bugger! I said, I will do without it, lol. I don't think I want to ask for a price for a new driver side window switch. It no longer lights up, and the spare one I have doesn't either. I will have to just stay in the dark!
Old Oct 14, 2012 | 04:11 PM
madsonp's Avatar
madsonp
Why was the switch causing your problems ?
Old Oct 14, 2012 | 04:39 PM
BigPigDaddy's Avatar
BigPigDaddy
I bet it's good to get that taken care of.
I know it doesn't help now, but that switch (oem Motorcraft SW5579) is available from Amazon for $80 or RockAuto for $90.
Old Oct 14, 2012 | 07:14 PM
DetailerDave
Not sure, I tested all the contacts previously, but it is common denominator, and replacing it cured all of the issues, so...............
Old Oct 14, 2012 | 07:15 PM
DetailerDave
I see that now, oops, a little late, lol, but it's all good now.
Old Oct 14, 2012 | 07:27 PM
BigPigDaddy
That's the way it goes sometimes.
At least you got it fixed.
Old Oct 22, 2012 | 12:11 PM
tboss619's Avatar
tboss619
I took mine apart cleaned all the connectors and she worked fine. this happens alot on motor homed cus they sit alot and corrison forms on the connectors and they dont make contact.
Old Oct 22, 2012 | 02:08 PM
thomabb's Avatar
thomabb
Those aren't sealed very well. Mine was really cruddy inside.
Old Oct 22, 2012 | 05:08 PM
BigPigDaddy
Do you go muddin' with the windows down?
By the way, your sig says "no mods" but I spy clear turn signals on the front.
Old Oct 23, 2012 | 07:25 AM
thomabb's Avatar
thomabb
She came from the Canadian oil fields. That light brown clay dust was EVERYWHERE! I still find traces of it sometimes. That was what I found inside the MF switch.
Old Oct 23, 2012 | 07:55 PM
DetailerDave
Don't it figure. I was out in my shed today, and ran across a spare M/F switch! The turn switch lever has a different bend to it, but otherwise it's the same.
Snuggyworm
Jan 17, 2012 09:25 PM
highboy390fe
Nov 19, 2007 09:19 PM
PMDRACER
Electrical Systems/Wiring
Mar 6, 2006 06:18 PM
rshad
1997 - 2003 F150
Oct 3, 2005 12:00 PM
Bedasi
May 4, 2005 02:54 PM
