Front axle leaking
Old Oct 23, 2012 | 08:04 PM
Tom's Avatar
Tom
Originally Posted by kconrad
I completed this project last weekend. It wasn't too difficult just time consuming. The worst part was getting the axles out. I tore up the outer seals getting them out but I had bought new ones to replace so it was ok.
Glad to hear you got it fixed! I've always been nervous to do work on an axle because I'm not certain I could get everything in there just right. I've seen stories about folks with trashed gears because the shop didn't get things right.
Old Oct 23, 2012 | 08:12 PM
kconrad's Avatar
kconrad
Yeah I just took my time and paid attention to how everything was put together.
Old Oct 23, 2012 | 10:38 PM
EXv10's Avatar
EXv10
Glad you got it fixed, I see why you wanted more info now. I guess I didn't think you were serious about tackling it.
Old Oct 24, 2012 | 06:48 AM
kconrad's Avatar
kconrad
I'm willing to figure anything out to save me BIG money. I saved around $700 doing it myself. It took three of 6-1/2 hours to complete. For anyone who ever taclkes this the tools you need is well worth the money!!!
Old Oct 24, 2012 | 07:53 AM
Treker58's Avatar
Treker58
I had a drip on the front passangers side also when I first purchased my X, never really leaked much but there was a droplet waiting to fall off for about 2-3 weeks. Fluid never went down, so it wasn't leaking while driving. The drop went away and and now is always dry but I keep my eye on it. The PO of the X was a builder and the X sat for a couple years when the building market went to crap. Guess that front seal got dry, but I think my driving it all the time may have gotten the seal lubed back up causing it to stop leaking. But as with everthing it is probably just a matter of time and I will need to replace it also. May be giving you a shout at that time to see if there are any afterthoughts you may have had about the replacement
Old Oct 24, 2012 | 08:21 AM
kconrad's Avatar
kconrad
Treker58, Anytime! Like I said previously it is not hard just time consuming. You will need at least two people especially when you get to the point of removing the carrier from the differential. That thing is HEAVY!!! I did have alittle problem getting the axles out due to the seal around them. I would recommend to anyone to buy new outer seals because I tore mine up getting them out.
Old Oct 24, 2012 | 09:25 AM
Treker58's Avatar
Treker58
You mention tools, did you need special ones? I haven't even looked at the repair manual to see what they list for tools needed.
Old Oct 24, 2012 | 09:59 AM
kconrad's Avatar
kconrad
Yes, you will need an Inner Seal Press tool and the tool to install the Outer Seals on the Axle and you use that same tool to hammer the drive shaft back into the knuckle housing.
Old Oct 24, 2012 | 01:46 PM
EXv10's Avatar
EXv10
Did your old seal/s show any signs of wear and tear? They seem like something that would rarely go out.
Old Oct 24, 2012 | 01:48 PM
kconrad's Avatar
kconrad
Yes my inner seals did. The outer seals were probably ok but I tore them up getting the axle out. I could have purchased an axle puller but I did not want to spend any more money on tools.
Old Oct 24, 2012 | 02:10 PM
housedad's Avatar
housedad
Congrats on the job! Doing it yourself always saves a bunch of money.
What tools did you end up getting?
Old Oct 24, 2012 | 02:11 PM
housedad's Avatar
housedad
Wooops. nevermind. I see you had just answered it.
Old Oct 24, 2012 | 02:13 PM
  #28
kconrad's Avatar
kconrad
I got the Seal Installer (QT1515) and Inner Axle Seal Kit (TS4643) from quad4x4.com.
ztodd377
May 16, 2011 11:08 PM
dmartinez21
Jul 26, 2010 01:57 PM
pbr man
Apr 9, 2009 01:26 AM
Tim Young
1966 - 1977 Early Broncos
Oct 5, 2006 10:49 AM
Cuda444
Nov 19, 2005 09:18 PM
