Warn hubs
Old Oct 23, 2012 | 07:34 PM
kconrad's Avatar
kconrad
Warn hubs
Hey guys. I jus trot done replacing my inner seals in the front differential and outer seals around the axles. I replace the OEM locking hubs with WARN hubs. I have read that vacuum hose going to the hubs needs to be blocked. My question is why? Is this the case for the EX? Everything seems to be working properly the way it is now which is the factory setup except for the new hubs. Can anybody elaborate on this for so I can understand it better.
Old Oct 23, 2012 | 07:43 PM
kornfanjoe's Avatar
kornfanjoe
I believe the reason is to stop the vacuum leak when you engage 4wd. Because other aspects of your truck use vacuum once the 4wd tries to engage it will have an open end and not be able to build any vacuum pressure thus rendering your heater controls useless. I'm not sure what else is run off of vacuum.
Plug them off. It's simple easy and saves a headache. I believe you can also remove the lines at/close to the vacuum pump to.eliminate the possibility of chafing or cuts causing a leak.
Old Oct 23, 2012 | 07:58 PM
kconrad's Avatar
kconrad
I still don't understand why though. Do the WARN hubs affect how the 4-wheel operates now? Do the WARN hubs change the operation?
Old Oct 23, 2012 | 08:06 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
yes they change the operation as they do not work with vacuum.....they are manually turned.....so if you dont block off the vacuum line then you will only have defrost in 4wd.....the warns engage like the factory hubs on the spindle but the operation of them is different.....
Old Oct 23, 2012 | 08:09 PM
kconrad's Avatar
kconrad
Ok, so where do I block this? At the hub or is there another location.
Old Oct 23, 2012 | 08:12 PM
indyF-350psd
stick a bolt in the back side of the knuckle to keep debris out....and buy some vacuum plugs and plug it at the joint where the 4x4 vacuum lines meet the main lines up near the top of the shock.....also it will help to un plug your vacuum solenoid valve by the vacuum pump up in the passenger side inner fender.....
Old Oct 23, 2012 | 08:20 PM
kconrad's Avatar
kconrad
So just find a bolt that will fit snug up in the knuckle.
Old Oct 23, 2012 | 11:28 PM
MagKarl's Avatar
MagKarl
When I put Warns on mine I left the vacuum lines hooked up. If I remember right, I traced the lines back and unplugged the pump. No problems and that was about 5 years ago. I didn't notice any changes to the HVAC like some have said would happen. Anyone know for sure what runs off of manifold vacuum and what runs off the pump on the gas rigs?
Old Oct 24, 2012 | 01:32 PM
EXv10's Avatar
EXv10
The stock hubs do the same thing as the Warns plus more which is why I don't see a need to go to Warn or Mile Marker hubs. You put all those nice new seals in there which affect the in-dash remote vacuum operation and then you eliminated it with aftermarket hubs. If your stock dial doesn't turn (too late now) that can be fixed also. I think a lot of people just like to spend money on the trucks in here.
Old Oct 24, 2012 | 01:45 PM
kconrad's Avatar
kconrad
Well my passenger hub was bad. The dial was the free mode but my axle was still turning. I pulled the hub off and spun the wheel and the axle was not turning. I put the hub back on and axle started turning again. I was told that the hubs could not be repaired and that I needed new ones. Can the OEM hubs be repaired? I still don't quite understand why the OEM hubs required vacuum lines and the new ones do not.
Old Oct 24, 2012 | 02:40 PM
cay5628's Avatar
cay5628
The orignal hubs worked when you enagaged 4wd for electronic shift on the fly operations, which when they work, does work well. However I tended to get out and lock them manaully during off road operations or in snowy conditions in case of vacum loss or hub vacum operation failure.
When I broke an OE hub I went with Warn hubs as well, no regrets. I put caps on the place where the line went into the hub and plugs in the lines and then zip tied the line out of the way. When you engage the 4wd, even with manual hubs now it still sends vacum to thru those hoses; better to plug em off and not get any debris in the vacum system or the port on the knuckle.
-Mark
Old Oct 24, 2012 | 03:02 PM
kconrad's Avatar
kconrad
Thank you for the clarification. I thought this is the way the OEM hubs worked but other people, including people that work in garages told me that was not the case. We have only owned almost two years now an last winter was mild so I never used it.
Old Oct 24, 2012 | 03:16 PM
EXv10's Avatar
EXv10
There are hundreds of used good hubs out there from being replaced with Warns.......too late now though. You say "we" so I assume you are married and women don't like getting out to turn hub dials. You can sell your Warn hubs pretty easily. Did I mention I don't like them? LOL
Old Oct 24, 2012 | 03:19 PM
cay5628's Avatar
cay5628
kconrad, you are welcome, that's the whole purpose of the site, to help and learn.... or is it learn and help? I forget! LOL That and the occasional dig and lots of laughter.
Take care - Mark
Punisher29073
Jun 12, 2013 04:06 PM
jrob_07
1983 - 2012 Ranger & B-Series
Oct 22, 2007 01:18 PM
SteveH-CO
Sep 8, 2005 11:58 AM
plumr
Mar 16, 2002 11:54 AM
