Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Fix Radiator Leak
Step by step instructions for do-it-yourself repairs
Radiator Leak...Need Sealant Feedback
2007, 4.0L, Explorer, 113,000 mi. Week ago noticed coolant expansion tank empty while hot and cold. Looked inside ex. tank and looked like it had not seen any action in a while. Looked inside radiator and coolant level was about 1 inch to 1.5 inches below bottom of rad. cap would be...approx. level with rad. seam, where black plastic top of rad. attaches to metal portion of rad. I filled expan. tank to "cold fill" line. Kept an eye on it while doing light, around town driving. The expan. tank level (cold-fill) didn't change.
Friday, my wife returned from work (30 mi., interstate drive). After being parked for 45 mins, went out to find fluid puddle at very front of car. Expansion tank was empty. Looked in radiator, and it was about one inch to inch and a half below bottom of rad cap...about level with rad seam, where the black plastic top is attached to metal. I topped off the rad. this time, along with filling expan. tank to cold-fill line. Turn car on, and after warming up coolant starting coming out from what appeared to be the seam at the top of the rad., where the black plastic portion meets the metal part of the rad.
As finances are a greater issue in my household than ever before (out of work for 10 months), I need to try and address/remedy the situation at home, before turning it over to the experts. I'm considering trying one of the radiator sealant products. Have you had or heard of experiences with these products? How about using it on a leak in this location? Any issues to be aware of? Any advice on application? Suggestions on brand to go with? Sincere thanks for any and all feedback.
SmittyVIP
SmittyVIP
Stay away from the "MAGIC" fixes..
I have had luck with seam leaks,
- Uninstall RAD,
- gently release the aluminum tabs,
- remove the tank,
- clean the gasket and channel,
- apply high temp RTV to gasket,
- set gasket and tank on rad,
- apply gentle pressure (to seat),
- let set overnight,
- clamp down the tabs (compress gasket),
- reinstall rad..
since you know where it's leaking & it's only the tank to core seal I'd just throw a 1/4 of a tube of Alumaseal in it. Some folks prefer using a dash of ground pepper, but i'd just use the Alumaseal.
When the level in the overflow bottle starts rising as the engine warms up & dropping as the engine cools down you'll know your leak ihas been fixed
Don't take something outside warranty to the dealer unless you want to spend way more than the repair is worth.
I have had good luck with just (carefully) tightening the crimps on the radiator core to tank connection, but the GM stop leak tablets really do work without clogging things up. They know their cars leak, so they have this to help with it.
I wish I could post a picture of what might happen to your radiator, depending, of course, on what type of product you use. I recently replaced the radiator on my '97 Aerostar and took the old radiator apart. The side of the radiator on the same side as the filler neck was coated with brown goo, as was the tranny cooler, which I'm sure reduced the effectiveness. The opposite side didn't have nearly as much, but there was still a coating. I can only assume the previous owner used some sore of stop leak.
A good number of the fins looked pretty much plugged. I couldn't see light through them. Rough guess is that the radiator effectiveness was about 60%. I wondered why my Aerostar ran hot on days that were not that hot (80F), even after replacing the fan clutch and thermostat. That crap is still coming out of the cooling system after a good number of drain/fills and a professional flushing. I'm concerned that my new radiator might get plugged up from the residual stuff that's left behind and flaking off.
I understand that money might be tight, but I would avoid the stuff. If you do the job yourself, you should be able to get parts for less than $200. If you pay someone else, you'll pay that much in labor.
bluesky636
07-06-2007 01:36 PM
Innovative Detailing
11-19-2006 07:38 PM
