Interior Question
Old Oct 4, 2012 | 09:40 PM
dtgl90vt's Avatar
dtgl90vt
Interior Question
So I am going to pickup my first/new truck up on Sunday and the interior is horrible, my plan is to follow Ems posts and repaint the dash, redo the carpet, ect.
I however am getting a crew cab and I would like to know if anyone knows if the back seat is the same as the front because mine is lacking one and I have nothing to compare too. also when I search car-parts.com I get nothing for the rears. So is the front and the back the same????
Also what are original interior colors? I want to do the red, I belive it is called Ox Blood, but I could be wrong.
Also what are the options for the seats? vinyl, velour?
Has anyone ever ordered the reupholstery kits like the ones from npd or lmc?? how did they work/look?
Thanks Guys,
Devin
Old Oct 4, 2012 | 09:43 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
on our 1989 Ford F350 the rear seat looks to me to be the same as the front seat but the front doesn't lean forward. I am not completly sure for older ones. Our 89 has cloth and red interior but it is an XLT Lariat.
Trav
Old Oct 4, 2012 | 09:58 PM
Gary Lewis's Avatar
Gary Lewis
Before you paint the plastic you should get all the old, dead, white plastic off. In fact, when you do you it may surprise you how good the plastic looks.
The door panels are made of pretty thick plastic, and you can sand on them a long time w/o sanding through. But the stuff coming off will load up your sandpaper in short order unless you rinse it under a small stream of water frequently.
Old Oct 4, 2012 | 10:00 PM
dtgl90vt's Avatar
dtgl90vt
Yeah, I have a question on that. Do you think if I sand it, I will loose the leather look, I want to keep it as original as possible and keep the leather creases in the dash.
Thanks,
Devin
Old Oct 4, 2012 | 10:09 PM
Gary Lewis's Avatar
Gary Lewis
Thanks,
Devin
Yes, it will lose the grain, or "leather look". But, if the plastic is dead, like what I see on many of the door panels, even a good coat or three of the SEM paint isn't going to make it look right or stay on. The chalky stuff has to come off, and in doing so the finish gets smooth, meaning w/o grain.
Old Oct 4, 2012 | 10:13 PM
4x484150's Avatar
4x484150
All bench seats from 1980-1996/7 have the same mounting spots. Only difference is the front benches dont tilt forward, due to safety.
For the panels, you might be able to get away with washing/sanding them, and repainting them the same color with SEM Products :: Home or LMC Truck Parts and Truck Accessories.
Edit: I see Gary beat me to the punch.
Old Oct 4, 2012 | 10:31 PM
dtgl90vt's Avatar
dtgl90vt
Ok I guess that's what I will go with, I know prep work is the most import part. But does anyone know the red color of the interior? And is it available from SEM?
Old Oct 4, 2012 | 11:59 PM
ctubutis's Avatar
ctubutis
Go to a local (automotive) paint store that can color-match your existing color, they can mix up SEM paint for you.
I was going to be getting some paint based on the color codes on the door-jamb sticker of my brother's Taurus but decided to do color-matching, instead.
Gr8Nate01
Jan 3, 2018 11:15 AM
Matt1966
22
Mar 10, 2017 02:26 PM
belshe92
May 2, 2016 10:06 AM
reamer
WTB - Parts & other
Feb 23, 2014 09:08 AM
JRB65
Jul 1, 2009 07:42 PM
