Starter engaging Flywheel
While rebuilding my truck I am hitting a little issue with the starter and flywheel. I noticed it while trying to rotate the crankshaft by hand to adjust my valve train. The starter is engaging the flywheel so I had to remove the starter to be able to freely rotate the crankshaft.
I looked at the starter and it appears the bendix is fully disengaged. I measured the starter and flywheel and found the starter bendix is about an 1/8" into engaging the flywheel teeth. As a test I put a washer in between the starter and engine block cover to push the starter back a bit but the washer was only about a 1/16th inch thick. This did help but the starter was still slightly engaging the flywheel.
I checked the flywheel installation compared to my original setup and it looks about the same although the new flywheel is slightly different in design. The tooth counter and diameter are the same as I verified that before installing the new flywheel.
The starter is new (reman) as well so I'm not sure what is wrong here. Do I have the wrong flywheel (please God no!) or the wrong starter? Can I install some sort of spacer to push the starter back 1/8"-3/16" of an inch?
This is in a '78 F250, 460, C6, 4x2.
Thanks all!
you are not crazy, it's your starter, I had the same problem,
https://www.ford-trucks.com/forums/1...g-starter.html
once you get a remanufactured, (you most likely gave back the core) you no longer know exactly what you had. If you really need to drive the truck, about a 5/16 spacer will do. But you will eventually chew up the starter. I chew up 5 starter in a row.
I went back to the scrap yards. At our scrap yard we remove the part ourself, after i removed 3 of them i found one, with about 5/16 different in lenght at the front of the starter. I re installed it, took me twenty minutes, never had any problem.
What the old man explained to me at the CarQuest, is that for those old ford, he recomment people compare the new one to the old one, before letting go of their core.
If you know the person where you bought the remanufactured one, ask him if you can check their inventory, one of them might be right.
Thanks for your feedback shotgun2. Its appreciated!
So even after using the 5/16 space you chewed up your starter? Did you use a spacer from NAPA like Jim described in post #24?
This has been resolved. Somehow I got the wrong part number from AutoZone. It was off by one digit so I guess they accidently pulled the wrong part from the shelves. I returned the starter and got the correct one and now I can freely rotate the crank without it engaging the flywheel. The correct part number was DL3152.
Thanks all for the help.
I bought the shim the same night I swapped the starter in case I still needed it but thankfully I do not need it any longer.
