wrong starter
Old Nov 26, 2011 | 11:05 AM
shotgun2's Avatar
shotgun2
wrong starter
good morning.
I have a 1978 F100, 300 I6
i swap engine, (1976 as per casting number ) and tranny.
i went from a 3 / tree to a wagner T19.
everything eventually worked. i had to move the cross member bracket.etc.
the only thing that is not right, is the starter.
(i used my old flywheel, the one that came with the 1976 engine was rusted and teeth missing. from the look of it, the two flywheel were identical)
For me to have a starter, i need to offset the starte by about .400 out.
(i cant figure out how to post picture on my message)
I bought so far 3 starter, before i realized it was hitting the flywheel once the engine was started.
one 1977 from the scrap yard. new 1978, new 1976. and finally the one in there is a new 1976 with 2 spacer.
can someone explain to me what i did wrong/ or is there a specific starter i need with a T19.
sincerely
G
Old Nov 26, 2011 | 11:42 AM
mikeo0o0o0's Avatar
mikeo0o0o0
According to the Ford parts catalog both the '76 and the '78 take the same starter, Ford D7TZ-11002-A, Motorcraft SA-712. It just differentiates between manual and automatic so apparently ALL manuals (3 or 4 speed) take the same starter.
Automatic trans trucks take a different starter, Ford DT0Z-11002-A, Motorcraft SA-709A.
However, both starters take the same starter drive.
Old Nov 26, 2011 | 06:37 PM
shotgun2's Avatar
shotgun2
i have picture, how do i post them here.
G
Old Nov 26, 2011 | 06:46 PM
shotgun2's Avatar
shotgun2
i finally figure it out.
i need the premium package to put picture. Duhhhhh.
Old Nov 26, 2011 | 06:48 PM
shotgun2's Avatar
shotgun2
does anyone know if there is a difference in the flywheel of a 1976 vs 1978??
G
Old Nov 26, 2011 | 07:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There is a difference in flywheels between '76 and '78 models. The first is 73-77 before s/n Y80,001, C5TZ-6375-N. The second is D7TZ-6375-F, this is for 77-up from s/n Y80,001. However they both use the same 164 tooth ring gear, C5AZ-6384-D. There is another ring gear that has 184 teeth but this is for the F-B500 and goes on a larger flywheel.
The only other thing I can think of would be that there is either excessive flywheel runout, the flwheel is warped or possibly the bellhousing is not full seated and square with the face of the block.
Other than that, I'm at a loss. Anyone else have any ideas??
Old Nov 27, 2011 | 08:38 AM
shotgun2's Avatar
shotgun2
wrong starter (wrong starter.JPG) - 9853839 - Free Image Hosting at TurboImageHost
new right side (new right side.JPG) - 9853838 - Free Image Hosting at TurboImageHost
new left side (new left side.JPG) - 9853837 - Free Image Hosting at TurboImageHost
The flywheel that is currently in the truck, was my original one.
it work nice never had an issue. I wnet back this morning under the truck, and i am thinking the bell housing is different...
g
Old Nov 29, 2011 | 12:37 PM
shotgun2's Avatar
shotgun2
I cannot see any real difference, (unless i CMM them).
Both housing, the one from the 3 speed and the T19, look like they match the engine exactly where they are supposed too.
Because the starter bolt to the housing, is it possible i need a completely different starter for a T19.??
G
Old Nov 29, 2011 | 12:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by shotgun2
is it possible i need a completely different starter for a T19?
The Ford parts catalog doesn't show a different starter between the manual 3 spd. and the T19, it only shows a difference between manual and automatic.
Old Nov 29, 2011 | 12:58 PM
shotgun2's Avatar
shotgun2
it absolutely drive me crazy, i know there is something. ( and most likley real stupid in the first place) i am missing.
But if i put the starter where it is supposed to go, look at the picture, the flywheel chew the aluminum portion of the casing circled.
and it chew the first 1/4 inch or so of the teeth of the starter.
correct me if i am wrong, the starter bolt directly to the tranny housing, no spacer of any kind, nothing.
the flywheel bolt directly to the engine, no spacer or any kind.
If the flywheel was off center by .400, the whole engine would shake like a earthquake.
Old Nov 29, 2011 | 01:00 PM
shotgun2's Avatar
shotgun2
Old Nov 29, 2011 | 01:10 PM
shotgun2's Avatar
shotgun2
comments??
that is exaclty what happen to mine, whine and grin as soon as I put a new starter in.
Originally Posted by EffoneHunded
hello again
according to autozone a 1976 and a 1978 with manual transmission the starter is different
autozone 1978 ford f100 300 Part Number: 3154
autozone 1976 ford f100 300 Part Number: 3132
i recently had to replace the starter on a 74f100. i bought the 1 yr warranty starter from o'reillys (Part # 03-0216X). the starter looked exactly like my old one but when installed and started it was whistling and grinding, i removed it and compared to my old one i noticed the bendix was longer on the new one. the manager at o'reillys was giving me a hard time because my old starter had oil/grime on it saying this was why, but i asked him to measure the bendix and he quickly found out he was wrong. he brought out another 1yr starter and it was also longer then he bought out a lifetime starter and for some reason it was the same as my old oil covered one. im not saying you have the same problem but anything is possible, ask to look at the bendix length on a couple starters for your year/transmission truck.
Old Nov 29, 2011 | 06:05 PM
mark a.'s Avatar
mark a.
You do have the rear engine cover plate on that goes in between the motor and the bell housing, don't you ?
Old Nov 30, 2011 | 10:08 AM
shotgun2's Avatar
shotgun2
yes, i do, the plate is there.
g
Old Dec 6, 2011 | 07:20 AM
shotgun2's Avatar
shotgun2
I fried one more starter....
this time i took picture under.
I still need to offset the starter.
Does the fly wheel appears to be at the right place? http://www.turboimagehost.com/p/9935..._8733.JPG.html
on the second picture, the fly wheel is flush with the recess on the housing. http://www.turboimagehost.com/p/9935..._8735.JPG.html
http://www.turboimagehost.com/p/9935..._8737.JPG.html
third picture is the "retarded" set up i need to do with the starter for it to run.
That truck need to run everyday to go to work, (during christmas break, i will pull the tranny, or the engine and see what is wrong tithe the flywheell) i have another one.
any idea... anyone.
