Starter and flywheel.
Old Aug 29, 2007 | 10:01 PM
gtsom6's Avatar
gtsom6
I went to put the flywheel back on today and of course forgot the mental picture of how it went on. I held it up there both ways, 1 hit rested on the bendix housing. The other way which is how I put it on, puts the teeth the furtherest away from the starter but there is still about an 1/8 of the starters teeth resting on the flywheel. Is this correct????
Old Aug 30, 2007 | 06:09 AM
Cuda_jim's Avatar
Cuda_jim
That can't be right if I understand you correctly. The starter and flywheel teeth should NOT be touching.
Is the starter gear fully retracted?
Roll the engine by hand to see if the flex-plate (flywheel) is a little warped. It can be somewhat warped until the torque converter is bolted to it.
