I recentaly had to install a new starter on my 94.5 psd,but when I went to crank it over the starter would engage but made a sound like it was not engaging with the flywheel right.So I tried it a couple of times and it engaged and started right up .
Is there something wrong with the flywheel??
Or is there somsthing wrong with the starter I bought??
You may need to inspect the flywheel teeth. Remove the 5 bolts from the inspection cover to view flywheel teeth,one of the bolts is located above the starter.
