egt and boost sensor placement
Old Sep 28, 2012 | 09:03 AM
maple sapper's Avatar
maple sapper
Whats the best place for an egt probe? I got my new exhaust parts today and the elbow that comes off the back of the turbo has a port with a plug. Is this the ideal spot for first egt? I also have read about drilling and tapping a hole in the actual exhaust manifold itself. Is there a completely different spot than what I am thinking. Or is both a great spot. What about two egt sensors? If two, then whats the best placement of each?
What about boost sensor? Is this on the front of the turbo? say for example do the AIH delete and then add boost sensor in its place? Doing alittle preplanning. Thanks
Old Sep 28, 2012 | 09:06 AM
timmyboy76's Avatar
timmyboy76
Ya, you'll get a more "real" reading with egt probe in the d/s manifold.
Boost wise, yup, look up riffraff boost/aih plug. Cant beat the item.
Old Sep 28, 2012 | 03:02 PM
SARDiverDan's Avatar
SARDiverDan
I drilled and tapped my exhaust manifold on the driver’s side. There is a nice open section there that is easily reached with a drill and tap set. I had been a little apprehensive about drilling into the part but after it was all over it really isn’t that bad and was actually very easy, a little stressful, but easy. My boost is run through the AIH so I can’t comment on other options.
Old Sep 28, 2012 | 04:04 PM
Tugly's Avatar
Tugly
I have a picture around here somewhere.... Maybe later. I have my pyro sensor in the driver-side manifold just before the connection to the up-pipe.
Boost: Remember that the AIH delete or the MAP line shows the boost reaching the engine, this is not always the same as what the turbo is doing. There is a 30 PSI limit for a stock turbo and my boost sensor says my boost is there. That's not to say you should do what I did, but bear this in mind if you ever shoot for the maximum boost as I have. I have a shiny new 38R on my work bench and I'll be learning how to configure the truck to get the maximum 40 PSI on that.
Old Sep 28, 2012 | 04:19 PM
timmyboy76's Avatar
timmyboy76
Hey Tug, to bad you didnt have enough of a liter, to plumb the boost sensor in where the MAT sensor is and vise versa. Also noticed, your boost is an electrical signal. I dont see any clear tubing from it. Wonder how "accurate" its reading.
Old Sep 28, 2012 | 04:30 PM
Tugly's Avatar
Tugly
OK... I read that like six times and I have no hair to catch the stuff that goes over my head, so I have to ask: "Enough of a liter"?
Old Sep 28, 2012 | 04:45 PM
BigAlsPSD's Avatar
BigAlsPSD
Me too, but I read it as long enough "leader" as in electrical leads, to reach the lower temperature sensor. But it's all speculation on my part too.
To the OP, the driver's side manifold is easily accessible and would be preferred as it will be showing a more direct indication of the temperature of the exhaust gas temps. The bung in your new downpipe may be for an EGT probe, but you will have to remember that if you install it there, you are losing a couple hundred degrees off of actual temps in the exhaust gasses.
For a boost sensor, either tap the MAP hose, or use the AIH delete plug Riffraff Diesel: RDP AIH Tapped Fitting
Old Sep 28, 2012 | 05:26 PM
CSIPSD's Avatar
CSIPSD
Keep in mind your boost pressure location will read 3-5 psi higher then others at about 30psi... Your reading HOT superheated air right out of the turbo. Its called pre IC boost. I run two boost gauges, one pre and one post IC... Post is 3-5 psi lower at 30 psi due to cooler air after the IC.
Its not right or wrong, just your data will be different then 90% of the people out there.
It will be more accurate then a mechanical gauge. Not to mention much easier to install and little to any chace of issues that a mechanical gauge lends its self to.
Old Sep 28, 2012 | 05:29 PM
CSIPSD's Avatar
CSIPSD
The rating on the stock turbo is 25psi... That is what it is rated for...
I have pushed a stocker to over 40 psi with a 1.00 exhaust housing and it lived. Drove that way for several weeks.
Its not the boost pressure that hurts the turbo, its the pressure differental that damages the bushings.
Keep in mind however anything above about 25-27psi is nothing more then superheated air, doing you no good.
Old Sep 28, 2012 | 05:59 PM
Tugly's Avatar
Tugly
25 PSI pre-IC? This is the first time I saw a spec different than 30. I need to look into this.
Ah... leader. That makes more sense... good catch! I have a longer leader, the service loop is out of the photo.
Old Sep 28, 2012 | 06:05 PM
timmyboy76's Avatar
timmyboy76
LOL...sorry Tug, been a looonnnggg day. Al got it, "leader".
Old Sep 28, 2012 | 07:41 PM
binuya's Avatar
binuya
Here's where most drill for the pyro sensor:
3-Gauge Install Pictures
They also have a good step by step for the drill and tap process. Not as bad as it might seem. For me, it was the easiest part of the gauge mounting project.
Here is my Isspro electronic boost sensor mounted in the AIH delete plug from Clay:
Old Oct 3, 2012 | 07:11 AM
maple sapper
So when removing the AIH, it's probably wise to undo the two wires as well? I may leave wires over the winter. Just in case I feel it's not doing well on the real cold days.
Also, the AIH plug looks like it may have pipe threads on it. Is that so or are they metric? I may even use a brass plug temporarily till riffraff one comes.
Thanks guys!!!
Old Oct 3, 2012 | 08:48 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Thanks guys!!!
Here are some instructions to help you out.
The hole is 1/8" NPT as you suspected.
Old Oct 3, 2012 | 08:54 AM
grec-o-face's Avatar
grec-o-face
Thanks guys!!!
I don't think the heater port is standard pipe thread. IIRC the Cummins oil pan drain plug fits it - if you can't wait for Clay's delivery. But honestly, it's not worth messing with it - just hold off for the Shiny RR piece.
Also, no need to keep the wires attached. The truck won't even know the heater is gone - and neither will you. You'll be fine without it!
sudsmcduff
Jan 11, 2015 09:57 PM
Tugly
Sep 18, 2012 01:25 PM
Tugly
46
Sep 5, 2012 01:09 PM
stinson 108-1
Jun 29, 2012 07:22 AM
STROKED-OUT
Apr 18, 2012 11:59 AM
